Author Topic: bad mpg  (Read 3119 times)
Offline Scottymk4
bad mpg
« on: 14 May 2015, 11:29 »
Hey guys,
I have a 1.8T AGU which only gets 245 miles to a full tank of fuel, 99% town driving but not ridiculously fast, idles fine and temp sits at 90 only serviced 6 months ago.....any ideas why I get such poor consumption ?  also no fault codes coming up.
cheers
Scott
Offline WadGTI
  • Golf GTI'er
Re: bad mpg
« Reply #1 on: 14 May 2015, 12:27 »
Migh be worth changing the fuel filter if not been done already. I would also check block 032 on vag to see what the fuel trim is sitting at.
Offline Scottymk4
Re: bad mpg
« Reply #2 on: 14 May 2015, 13:31 »
ok, wil take a look at block 032 tonight...what should the readings be
« Last Edit: 14 May 2015, 17:09 by Scottymk4 »
Offline WadGTI
  • Golf GTI'er
Re: bad mpg
« Reply #3 on: 15 May 2015, 09:23 »
the closest to 0, the better,
worth checking out this http://forums.vwvortex.com/showthread.php?1265064
Offline Scottymk4
Re: bad mpg
« Reply #4 on: 24 May 2015, 16:25 »
took a while to get around to hooking up to vag com but when i did block 032 all 4 fields say N/A.... any ideas why this is?
Offline itavaltalainen
Re: bad mpg
« Reply #5 on: 24 May 2015, 16:43 »
99% town driving? Then not surprised you need a lot of fuel. My 1.8 75hp mk3 estate was often empty when only driven short distance in town after 250-300 miles, never mind it has 60 liter tank.
Offline Scottymk4
Re: bad mpg
« Reply #6 on: 24 May 2015, 16:50 »
yeah I expect slightly lower mpg but think that really low :cry:
Offline reedy20vturbo
Re: bad mpg
« Reply #7 on: 24 May 2015, 17:15 »
My 1.8t aum seems to be running very rich and stinking of fuel, I checked block 32 and idle is -2.3% and partial is -19.5 it keeps bogging and I get funny jerky boost, just fitted new maf, and no difference could this be a bad 02 sensor precat?
Offline Scottymk4
Re: bad mpg
« Reply #8 on: 24 May 2015, 17:30 »
Not sure mate but I don't get any readings at all on block 032
Re: bad mpg
« Reply #9 on: 24 May 2015, 17:39 »
Does the agu ecu support that feature?
