Author Topic: Vibration when turning right  (Read 1994 times)
Offline Momosan
« on: 10 May 2015, 19:33 »
hello wondered if anyone could help me
My mk2 golf (low on coilovers) has a terrible vibration / clunk when turning right.
Started after having the o/s drive shaft and top mounts changed. Previous to this its been fine for years.
Ive taken the suspension off and everything looks ok, ive replaced the n/s tie rod end and rear engine mount and still nothing.
The n/s caliper lower bolt is tight but doesn't seem as far in as the o/s but its rounded so cant tighten it.
Would that cause a vibration ? or do I need to go down the wheelbearing route ?
Any help would be appreciated.
Offline sparkplug
Re: Vibration when turning right
« Reply #1 on: 11 May 2015, 18:51 »
i would check the drive shaft bearing, it may not be seated right ?
1986 GTI atlas grey
Offline gazareth
« Reply #2 on: 11 May 2015, 20:00 »
do you mean while your turning right or when your moving on right hand lock?
