Golf mk3
hardmonkeys
water inside car
Topic: water inside car (Read 5617 times)
danmusic24
water inside car
02 May 2015, 18:13 »
losing water and after a quick look round nothing!
then inside car there is brown water staining on carpets at back of centre console?
heater matix? if so is it a pain job???
Foreveryoungaus16v
Re: water inside car
02 May 2015, 19:11 »
Could be many things, take it somewhere to get it checked
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
VW BUSH
Guest
02 May 2015, 19:19 »
Dash out lots of swearing if it's the matrix
madmanmart
02 May 2015, 19:39 »
If it's brown then there's ypur problem, lack of coolent causing matrix to corrode.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
danmusic24
02 May 2015, 22:36 »
k seal? quick fix???
madmanmart
02 May 2015, 22:44 »
No the quick fix is to link the two matrix pipes going through the bulkhead. It's summer so you don't need heaters anyway.
danmusic24
Reply #6 on:
02 May 2015, 23:21 »
dont sound good,pls dont say dash out to fix it???
VW BUSH
Guest
Reply #7 on:
03 May 2015, 00:35 »
Quote from: danmusic24 on 02 May 2015, 23:21
You could maybe bridge it out engine side and not fix it, then pray for a warm long summer
Gti_Jamo
1991 Corrado 1.8 G60
Reply #8 on:
03 May 2015, 11:20 »
Dash out i'm afraid. It's not that hard but a good afternoons work.
97' Mk3 Golf Gti 2.0 8v Rebuild Project
http://www.golfgtiforum.co.uk/index.php?topic=208865.0
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Reply #9 on:
03 May 2015, 12:21 »
Hmmm!! Lovely job to sort!!
For me it was good as the last owner had attempted to bodge the leak and I found all sorts of broken parts/iffy wires when It was apart!
Golf mk3
hardmonkeys
water inside car
