Author Topic: FRONT FOG LIGHT WIRING HELP  (Read 1593 times)
Offline Brummieboy
« on: 29 April 2015, 10:38 »
just bought some front fogs for mk4 gt tdi. on each light there is an earth and live wire which i am meant to wire. where do i wire these into? into main lights? if so which wire goes where?
Offline itavaltalainen
Re: FRONT FOG LIGHT WIRING HELP
« Reply #1 on: 02 May 2015, 22:24 »
What fogs do you have?
You will need:
fogs (obvious)
main light switch that has fog switch
relay
wiring loom, you will need to pin in some stuff in CE and also install relay
