Author Topic: Removing my rain tray - easy question!  (Read 3729 times)
Offline general_piffle
« on: 27 April 2015, 20:49 »
Hi, trying to remove my scuttle panel / rain tray to check the ECU code so I can get a chip but the large flat mushroom clips that hold it in place just spin around when I try to unscrew them without coming out.
How can I get the little buggers out?! Cheers :)
Offline itavaltalainen
Re: Removing my rain tray - easy question!
« Reply #1 on: 27 April 2015, 21:17 »
Use a flat screwdriver and prise the outer part of the clip slightly up while you're undoing the pin in the middle with a screwdriver. This will stop em from spinning. You only need to undo a few turns - then you can pull them out (both parts should come out still attached to each other - otherwise you've undone it too much).
What engine do you wanna fit a chip too?
« Reply #2 on: 27 April 2015, 21:34 »
Ah, that makes sense cheers! It's a 16 valve GTI MK3.
Offline Foreveryoungaus16v
« Reply #3 on: 28 April 2015, 08:01 »
Get the chip from this guy ebay 271789306325
163 BHP (TSR POWER RUN)
« Reply #4 on: 28 April 2015, 21:02 »
Thanks will do. Have you got one, any good, notice any difference?
If it's the type that just plugs in I'll go for it but if it's a solder job I might not bother.
« Reply #5 on: 28 April 2015, 21:26 »
Yes it just plugs in. It did make a little difference about 5 bhp at most.  :smiley:
« Reply #6 on: 28 April 2015, 21:34 »
There is a good guide on u tube On how to: install a chip on a Mk3 volkswagen ecu
« Reply #7 on: 29 April 2015, 00:14 »
Thanks, just found it, guy with the crazy hair.
Am I right in thinking you have to disconnect the battery even with the engine off before removing the ECU / chip?
« Reply #8 on: 29 April 2015, 04:45 »
Yeah if I remember correctly I did
« Reply #9 on: 29 April 2015, 16:46 »
I would always disconnect battery when working on electrics (be aware of your radio code though).
