Author Topic: Road tax - 5dr DSG GTD  (Read 17148 times)
Offline Silvadadi
« on: 25 April 2015, 19:02 »
ive read that 5dr DSG GTD's pay more road tax than £30 for manuals - is this correct as renewal is imminent?
Ordered Jun 18: R 5dr, IG, DSG, Prets, DLA, climate w/s and tints.
Aug 14 - Jul 18: GTD 5dr, CSG, DSG, S&S pack, Vienna leather and Santiago's.
Offline Diehammer
Re: Road tax - 5dr DSG GTD
« Reply #1 on: 25 April 2015, 19:32 »
Manual is £20 IIRC the DSG is a fair bit more.
Golf GTD MK7 5 door Manual, Carbon Grey, Keyless Entry, Rear View Camera.
Ordered 26/02/15  Build Week Confirmed 24/04/15 (BW21) Stage 5a 19/05/15 Stage 5b 21/05/15 Stage 5c 29/05/15 Stage 6 02/06/15 Stage 7 04/06/15 Pick Up 06/06/15
Offline mcmaddy
« Reply #2 on: 25 April 2015, 20:01 »
Dsg is 110 quid I think.
Offline fredgroves
« Reply #3 on: 25 April 2015, 22:21 »
Band B for manual (£20), Band D for DSG (£110).
Offline Mark V GTD
« Reply #4 on: 26 April 2015, 10:08 »
But three-door DSG's remain at 30 quid...
Offline fredgroves
« Reply #5 on: 26 April 2015, 10:18 »
VED bands B (£20) and C (£30) for 3 door.
I can't really work out why it makes so much difference, other than some arbitrary figure the government has decided is a "bad" co2 figure.
Offline Silvadadi
« Reply #6 on: 26 April 2015, 23:11 »
Thanks for replies.
I'm sure when I took delivery from the dealer the tax disc showed £30.........will have to check it again.....is there a difference between tax at first registration and renewal?
Offline fredgroves
« Reply #7 on: 27 April 2015, 08:01 »
Its quite easy, just go to the VW website, start building a new car, choose whether or not your car is 3 or 5 door, select the engine (DSG/manaual) read the info on that page and it tells you the VED band.
Then, go here and discover how much they want to rob you:
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/419799/V149_Budget_2015_Final_version.pdf
Offline Sootchucker
« Reply #8 on: 27 April 2015, 08:04 »
Never, ever understood this.
The 5 Door DSG version has a higher CO2 output than the 3 door which pushes it into the next tax bracket. Fair enough you would think, the 5 doors obviously add a bit of weight and therefore push the CO2 up. However if you check the manual versions of the GTD, both 3 and 5 doors are exactly the same CO2 output, and even more bizarrely, if you look at the GTI, it doesn't affect the groupings all be it manual or DSG, the 3 and 5 door versions are exactly the same ?
For example:
GTI - 139g Manual - the same for 3 door and 5 door - VED Band E
GTI - 148g DSG     - the same for 3 door and 5 door - VED Band F
GTD - 109g Manual - the same for 3 door and 5 door - VED Band B
GTD - 119g DSG     - 3 door only                            - VED Band C
GTD - 122g DSG     - 5 door only                            - VED Band D
WTF ?
« Last Edit: 27 April 2015, 08:07 by Sootchucker »
Offline fredgroves
« Reply #9 on: 27 April 2015, 09:38 »
It looks to me like the DSG box adds roughly 10g/km (which is surprisingly efficient compared to older automatics it has to be said!). Quite possibly the difference is actually weight? I have no idea what the weight differences are mind you.
What's the weight difference between a 3 door and a 5 door manual GTD? I couldn't find that either.
However, the 5 door DSG figure is really odd, unless there actually is a weight difference between the 3 door and the 5 door?
BTW, I didn't answer Silvadadi's other question - yes the first registration fee is different to the subsequent renewals - its all on that link I put up for tax rates.
