Author Topic: V5 to V6 Engine Questions  (Read 3986 times)
Offline th3_f15t
« on: 25 April 2015, 16:48 »
I have an AGZ V5 engine (10 valve 150bhp) but thinking of replacing it with a V6 from a 4motion. Is there any reason in theory why a V6 won't fit into place of the V5?
Provided I got the engine, ancillaries, wiring loom and ECU, it should all go in, connect to my V5's existing gearbox (unless someone can recommend a better one to swap in at the same time, a 6-speed from a GTI perhaps?) and run?
Basically, doing it for fun and to learn, but thought I may as well pick up a V6 engine as it's the same price as the V5 and there's more overhead and support for a little tuning.
« Last Edit: 29 April 2015, 17:40 by th3_f15t »
Moving over to Flickr, sorry for the broken picture links!
Offline barrym381
Re: V5 to V6 Engine Questions
« Reply #1 on: 30 April 2015, 19:32 »
just fit the 1.8t instead if you want to tune it as both the v5 and v6 are expensive to tune past a simple map  :smiley:
Offline th3_f15t
« Reply #2 on: 03 May 2015, 11:26 »
I had considered a 1.8T BAM engine swap, but the point isn't about hitting huge numbers, it's about the sound and feel of a V6 engine. This is going to wind up more of a cruising/show car than an all out performance machine. That honour will go to my mk5 GTI.
It's all well being logical about it and going "put a 1.8T lump in", then you think "why not get a 4motion car and use that instead", which evolves into "just get an mk4 R32 then" and soon becomes "why not get a mk5 R32"... You see where I'm going with this!
Offline Waspy
« Reply #3 on: 22 May 2015, 14:00 »
Just get a mk5 R32 mate
 :wink:
Offline th3_f15t
« Reply #4 on: 29 May 2015, 18:51 »
 :wink:
You mean the engine from it, yeah? Been thinking about that... :whistle:
