Author Topic: What happens if..?  (Read 5211 times)
Offline Max Q
What happens if..?
« on: 24 April 2015, 22:15 »
Hi folks, recently got my new GTI and have two questions I can't find answers to in the manual.
1) With the KESSY system, what happens if the engine start button is pressed while driving? I presume the engine won't stop with the vehicle in motion?
2) With the electronic parking brake, what happens if the button is pulled up (say by a dopey passenger who pulls on the button not realising what it does) while the car is in motion? The manual seems to indicate it will apply the handbrake as it can be used in emergencies for stopping the car. Is that correct?
Mk7.5 R DSG Indium Grey 5Dr
Offline Diehammer
Re: What happens if..?
« Reply #1 on: 24 April 2015, 22:22 »
Not sure about KESSY but the handbrake button doubles as an ejector seat release for dopey passengers.
Golf GTD MK7 5 door Manual, Carbon Grey, Keyless Entry, Rear View Camera.
Ordered 26/02/15  Build Week Confirmed 24/04/15 (BW21) Stage 5a 19/05/15 Stage 5b 21/05/15 Stage 5c 29/05/15 Stage 6 02/06/15 Stage 7 04/06/15 Pick Up 06/06/15
Offline remlapeel
« Reply #2 on: 24 April 2015, 22:22 »
If you press the start button it asks if you are sure you want to turn the engine off and says press it again to switch off engine.
No idea about the handbrake....but I am curious.
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Jimble
  • Moderator
« Reply #3 on: 24 April 2015, 23:31 »
The electronic handbrake will apply the brakes similar to a normal handbrake, tried it on a quiet car park once.
Offline Vedubber
« Reply #4 on: 25 April 2015, 06:30 »
if you pull the handbrake up it will act alomst like an 'emergency stop' button. bringing you to a stop VERY quickly!!
MY13 Polo GTI - MY14.5 Golf GTI PP - Now MY15 VW Up!
Offline Max Q
« Reply #5 on: 25 April 2015, 09:21 »
Thanks for the replies. Good to know that the engine won't stop if you accidentally hit the start/stop button.
@Diehammer I must look in to that mod for the passenger ejector seat if they touch the handbrake button. :grin:
Offline itavaltalainen
« Reply #6 on: 25 April 2015, 09:23 »
Kessy - push the button once while in motion and it gives you a message on the screen that if you press it again it will turn the engine off (it will if you press it second time - tried it).
EPB button - pull it up at low speed (iirc below 5 mph) it will activate the EPB, if you're going any faster it will apply approx 75% of full braking power to ALL wheels through your normal brake setup. Quite some deceleration :D
Offline Max Q
« Reply #7 on: 25 April 2015, 09:29 »
Not to be tried at motorway speeds then!
Offline fredgroves
« Reply #8 on: 25 April 2015, 10:47 »
No, that's for Range Rover owners only.
Offline dv52
« Reply #9 on: 26 April 2015, 03:18 »
Diehammer: The SEAT EJECTION function for the handbrake button only works if you have enabled Bit 0 on Byte 10 in the control module (see below)
But on my car, I've added the function to my "secret arsenal" buttons which I fitted just above the centre console (see below). These are not standard VW options. But I find that it's particularly important to have the complete suite of extra goodies for those times when my mk7 is pursued by the occasional super-evil villain (will happens remarkably often)!
« Last Edit: 26 April 2015, 06:18 by dv52 »
103TSI Highline ROW (my13)
