Author Topic: Speaker Vibration  (Read 6648 times)
Offline GrahamFR
Speaker Vibration
« on: 23 April 2015, 09:39 »
Hey all, so my door speakers are starting to rattle or at least it sounds like the rattle is coming from them, just the passenger one as well to be honest.
Is there a guide somewhere on how to take off the plastic front? Is it a pita or simple? And I was going to just get some sound proofing strips and packed round it, unless others can advise differently?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline monkeyhanger
Re: Speaker Vibration
« Reply #1 on: 23 April 2015, 18:37 »
Warranty job, let the dealership do it.
Offline GrahamFR
« Reply #2 on: 24 April 2015, 08:10 »
well it sorta only vibrates at 11...  :rolleyes:
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline dv52
« Reply #3 on: 24 April 2015, 10:22 »
Graham: have a look at the link below. It's an instruction about how to add folding mirrors, but it does show how to remove the door trim.
cheers
Don
http://www.uspmotorsports.com/downloads/M001-Instructions.pdf
103TSI Highline ROW (my13)
Offline GrahamFR
« Reply #4 on: 24 April 2015, 10:34 »
So the speaker is fixed to door and not inside a separate compartment? This seems painful, maybe a bash at the stealers might be in order, all i wanted to do was stick a bit of insulation around the speaker :sad:
Here's a mk2 leon guide... so much easier lol  http://www.no1wok.co.uk/cupra/dpf.pdf
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline dv52
« Reply #5 on: 24 April 2015, 13:44 »
Graham: Yeah, lot easier on the mk2 . On the mk7 the front bass speakers insde the doors are held to the door frame by four pop-rivets (see pic below). Strange that they have become loose - are you sure that it's a problem with the fixings and not an issue with speaker diaphragm?
Offline GrahamFR
« Reply #6 on: 24 April 2015, 14:04 »
If it is, would this most likely fall under wear and tear?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline p3asa
« Reply #7 on: 24 April 2015, 22:12 »
Have you plugged it into VCDS?
My Mk6 had a speaker that was vibrating. I couldn't believe it when it was flagged in VCDS! Dealer changed it no problem.
Offline dv52
« Reply #8 on: 25 April 2015, 02:06 »
p3asa: Wow- that does surprise me!!
I would have thought (incorrectly as it now seems) that if a VCDS cable could detect a fault in a speaker, it would need to be an electrical problem (i.e. something like an open/shorted transducer coil). Sure, a damaged speaker diaphragm does vary the "loading" on the speaker coil, but I assume that this would be a subtle effect.
Anyhow, any new piece of information is always valued!  Can you remember what the error message in the autoscan report was?
Offline p3asa
« Reply #9 on: 25 April 2015, 19:42 »
No sorry. I didn't have a VCDS cable then.
I took it to the dealers expecting to be brushed off. I also had a problem with my music stuttering between tracks so had made up short pieces of music on my ipod as I just new they would ask for a demonstration.
So low and behold they asked me to go into the car with a mechanic to show them and while we were there he told me the speaker had shown up on their diagnostics.
