Author Topic: Keys - Weirdness  (Read 4581 times)
Offline mustard
  • Mk7 R
Keys - Weirdness
« on: 22 April 2015, 06:19 »
The key I normally use opens all the doors and the boot when I push the unlock button and the car autolocks when I drive off. However the set I keep as a spare only unlocks the drivers door and requires a second push to unlock all the doors and the car does not autolock.
I have set and reset the locking in the MFD many times but this doesn't make a difference.
Anyone else experienced this and does anyone have a solution?
Offline J400uk
Re: Keys - Weirdness
« Reply #1 on: 22 April 2015, 06:32 »
Mine does the same. Each key has its own personalised settings. Have you tried changing the MFD settings whilst the spare set is in the ignition?
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
Offline mustard
  • Mk7 R
« Reply #2 on: 22 April 2015, 06:40 »
Yes, have done that, makes no difference.
Only thing I can think of is that I had a new BCM, after that the key didn't work at all (no surprise) and the dealer recoded the key.
Offline Booth11
« Reply #3 on: 22 April 2015, 07:42 »
My spare only unlocks the driver's door too.  Haven't tried resetting the MFD yet, will try later.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #4 on: 22 April 2015, 08:23 »
Just tried resetting MFD with spare key in ignition, didn't work.  So tried resetting mfd with key in ignition and engine running, vehicle stationary.  It works.  Spare key now unlocks all doors.  Try that.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Keithuk
« Reply #5 on: 23 April 2015, 03:07 »
You have to program each setting you change on both keys. Those settings can be done in the MFD settings.
I know because I had the DRL's turned off when I bought the car. A couple of years later I tried my spare key to make sure the battery was ok and the DRL's were back on again, so I manually turned them off again.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mustard
  • Mk7 R
« Reply #6 on: 23 April 2015, 15:00 »
Thanks Rebecca and Keith,
I had already tried setting it with the engine running, however I ran the engine, unchecked all the functions, stopped the engine got out and locked the car, unlocked it, started the engine and rechecked all the boxes and:
It now works.
Offline Booth11
« Reply #7 on: 23 April 2015, 17:12 »
It now works.
When I tested it on mine I also unchecked everything first then reticked the 'open all doors' box, switching engine off in between.
Glad you got it sorted  :smiley:
« Last Edit: 23 April 2015, 17:24 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Obbzi
« Reply #8 on: 04 May 2015, 09:37 »
What menu is this under?
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Booth11
« Reply #9 on: 04 May 2015, 10:40 »
In the DIS on mine it's under Convenience - Central locking - Door unlocking
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
