Author Topic: ross-tech  (Read 3103 times)
Offline welshvalver
ross-tech
« on: 12 April 2015, 14:36 »
hay guys probably been asked before but which vcds do i need for my mk3 gti 8v. thinking of downloading it on my laptop.
cheers
Offline vicciu
Re: ross-tech
« Reply #1 on: 12 April 2015, 16:53 »
It depends on which cable you bought. I bought a cheap 10$ cable and only VCDS Lite worked with it.
Offline itavaltalainen
Re: ross-tech
« Reply #2 on: 12 April 2015, 17:49 »
You either need the Hex+Can interface if you want to use full VCDS on a mk3 or VCDS lite which will work with all KKL cables (some better than others) but that is limited in function unless you register it for 99$.
Offline welshvalver
Re: ross-tech
« Reply #3 on: 23 April 2015, 22:10 »
cool chees guys i think il get the registerd one
Re: ross-tech
« Reply #4 on: 23 April 2015, 23:27 »
good choice for mk3.
btw what do you need it for?
Offline N900 MJT
Re: ross-tech
« Reply #5 on: 24 April 2015, 10:53 »
There isn't a lot that you can really do on a mk3 with vagcom, but for fault checking of the engine the Lite version does just fine
VW BUSH
Re: ross-tech
« Reply #6 on: 25 April 2015, 13:38 »
