Author Topic: 89 8v PB won't start  (Read 3446 times)
Offline joker6789
« on: 11 April 2015, 19:44 »
Just s quick one before I attempt to fault find with limited knowledge. Classic day before Spring GTI Fest!
does this wire need connecting?
any help appreciated!
thanks
James
Offline Mr Blue
Re: 89 8v PB won't start
« Reply #1 on: 11 April 2015, 23:09 »
blue? That is the alternator exciter wire. Yes needs to be connected.
Offline Waspy
« Reply #2 on: 12 April 2015, 00:11 »
In terms of not starting. A little more info would be good. Is it just not firing? Not cranking?
From that pic the power to your starter doesn't look too tight, as a side note
Offline gazareth
« Reply #3 on: 12 April 2015, 00:41 »
a quick question is one thing but that one was a bit to quick :grin: you need to find the wire that connector has fallen off and re-connect it. then charge your battery up and all should be well.
Offline joker6789
« Reply #4 on: 12 April 2015, 18:46 »
Thanks everyone! I just had to strip back and re-connect that wire and the battery started charging again.
