Author Topic: Help with fault  (Read 1756 times)
Offline 1 gti
Help with fault
« on: 10 April 2015, 18:46 »
Hi, I'm after some advice after exhausting all my knowledge on this. The car is a 52 plate 1.6 16v with 35k on the clock.
The faults which have come up are :
17550 - load calculation cross check
01314 - Engine control module 013 check memory, intermittent.
also, barometric pressure/manifold fault code.
I've changed the EGR valve, MAP sensor and throttle body and these faults still come up with the engine management light, EPC light and traction control light. I've adapted the throttle body and EGR valve before starting as well.
The car is ticking over at about 1050RPM.
I've read online about a faulty ECU but i don't want to buy one if its not going to solve the problem.
Any advice will be greatly appreciated.
