Author Topic: Golf Mk4 2.0 Overfuelling  (Read 2131 times)
Offline golfgtimk28vman
« on: 09 April 2015, 15:57 »
Hi,
I have a Golf Mk4 2.0 petrol and the average MPG has dropped dramatically, going from a steady 32 to a eye watering 19 MPG. Does anybody know what the problem could be?
There's no engine management light that's come on, although a friend with a diagnostics unit did come up with the following codes : P0171 and P0134.
It's going into the garage tomorrow, but can anyone help with advice so that the garage doesn't mug me for a job that doesn't need doing and it still have the problem? Has anyone had this problem and solved it?
Many thanks in advance!
Offline Kitten
Re: Golf Mk4 2.0 Overfuelling
« Reply #1 on: 09 April 2015, 23:00 »
My 2.0 has just started doing the exact same thing. I haven't managed to get it looked at yet though, might have to wait until Monday :-( I noticed mine dropped to 26mpg on a motorway trip, normally I'd get 36. And only 244 til the petrol light came on.  :sick:
Offline Kitten
« Reply #2 on: 10 April 2015, 08:59 »
I've been looking around the interweb and chatting with my colleagues and it seems that fuel additive like cataclean or bg44 is worth a try. Also I might stick in some Shell v power, see if that helps clean the system. I might otherwise normally fill up on the cheap stuff at supermarket petrol stations :whistle:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 10 April 2015, 14:04 »
A quick google search with those numbers
http://www.obd-codes.com/p0134
http://www.obd-codes.com/p0171
Basically you have a dead pre cat lambda sensor
Offline Kitten
« Reply #4 on: 14 April 2015, 23:42 »
Got the diagnostics on my car and no surprises lambda sensor showing fault. Had been noted as intermittent last service. I put the bk44 in, I've only done 11 miles and already the average mpg on the trip computer has gone from 26 to 33mpg. Let's see how long a tank lasts...
