Author Topic: Oil pressure probs  (Read 3535 times)
Offline Thegavo
Oil pressure probs
« on: 05 April 2015, 23:43 »
Hey guys, quite concerned about this, whilst driving thru town on the flat after a 50 mile drive, I pulled away from the lights and mfd started beeping and flashing "stop engine" oil pressure" so I did, I checked oil level and it was on bottom of dip, I restarted and no warning lights came back on so I drove gently for a mile to nearest garage to check/top off oil properly, I bought 1 litre of magnatec and poured it in bit by bit till it started to register, I managed to get it all in, 1 full litre, started it again all ok,  I drove another 6 miles ish to get home, I was pulling into my estate when it happened again, beeping and flashing stop engine, I pulled over and stopped, waited 5 then started and fine but as I went over speed bumps it started going crazy, going off and on and on n off? I pulled into my drive and turned off, that was it for the night as dark nd late, went to bed and just left it over night, when I checked it this morn the oil i put in had now settled overnight and was just a millimetre over the max... So plenty oil was put in , I started it up and no warnings came on, so I took it out for a run, it went great for 45 mins , so I headed back home, then as I drove down my street it came on again" stop engine" beep beep beep,
can anyone please shed any light on what it is and what can I do now? I'm demented, any help would be apreciated thanks Gav
Offline MK4_20VT
Re: Oil pressure probs
« Reply #1 on: 06 April 2015, 11:58 »
My 1st thought is your oil pump is knackered.  I managed to split mine in half, the engine would not turn over & when it finally did soon as the rev's went above 1100 beep beep oil pressure.
Or the pickup could be blocked?
Jay
Offline th3_f15t
« Reply #2 on: 06 April 2015, 12:19 »
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html - This is worth a read mate, sounds very much the same story I've heard a lot before. The oil pick-up pipe gets blocked and starves the engine of oil. Quite serious and I'd advise getting it sorted ASAP.
Moving over to Flickr, sorry for the broken picture links!
Offline Thegavo
« Reply #3 on: 06 April 2015, 15:30 »
Wow thanks for that link, that's alarmingly like my story! Not used car since, might have a go at that, let's hope that's what it is! I do actually feel sick with worry as its a cracking car and I would not be able to replace it.. Thanks again il keep yous updated...
Offline th3_f15t
« Reply #4 on: 07 April 2015, 08:36 »
Don't worry too much almost everything is repairable. And if you think a job is beyond your skills, just remember even the best mechanic started out clueless about how to change oil.
You're doing the right thing by not driving it until it gets sorted. I think, according to Jay who wrote the guide, it's a few hours work on a nice day to sort out.
Offline Thegavo
« Reply #5 on: 08 April 2015, 00:06 »
Well took afternoon off and got stuck in to the car!, lovely sunny day here so took my time and followed that guide, it took me 4.5 hrs but I did it on my own. When I got the sump off I was praying the pick up pipe would be blocked, I got my wish !! It was it seemed blocked completely, how any oil got thru that collander at all is beyond me, really bad. Vw recommended renewing the sump plug too, so I did, it was only £2.70. The oil filter was really bad too to be honest, I tend to wonder if it's been left in and they've just changed the oil, I guess not many people are gonna take the oil filter back out after a service to check really.. Anyway I managed to do it, there were some challenges like the gearbox bolts and then getting the sump back on was a bit tricky too, would be easier with a mate but it's doable yourself. So got it all back together , oil in etc, except for the under tray ( so I could check my work) and fired it up, all was ok, no leaks, no noises, sounded good, put tray back on then out for a blast, brought it up to temp,  steady away. Once it was up to temp I gave it a few blasts and it went well, it all seems fine so far, feels smoother and possibly quicker ?? Is that possible??
Anyway thanks for the replies, it was a big help linking me to that sticky, hopefully that's it sorted, I'm well relieved cheers guys
Offline th3_f15t
« Reply #6 on: 08 April 2015, 07:32 »
If normal oil flow within the engine is now the case then yes, you will see performance and economy gains. Now go enjoy her!
