Author Topic: Purpose of those holes in the floor?  (Read 5951 times)
Offline Waspy
« on: 02 April 2015, 12:24 »
Hey guys. My job over easter is to strip the now failing underseal from the underbody of the car and paint with top notch protective paint.
My question: In some of the box sections under the car there are holes, maybe an inch in diameter. What is their purpose? Just seems like a moisture trap. Can I blank them off?
VW BUSH
Re: Purpose of those holes in the floor?
« Reply #1 on: 02 April 2015, 16:09 »
They lets the water out
Offline Waspy
« Reply #2 on: 02 April 2015, 16:14 »
If they were blocked, how would water get in? Genuine question haha
Offline jv
  • Administrator
« Reply #3 on: 02 April 2015, 16:23 »
Leaking door membrane or through the heater usually
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Waspy
« Reply #4 on: 02 April 2015, 17:29 »
I mean the ones under the car, like this (excuse the rust, that's what I am busy sorting out) Or are those the ones we are all talking about? The ones that run parallel to the sills are all blanked off with rubber grommets, but these ones arnt
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 02 April 2015, 20:25 »
A body shell is constructed using pressed panels that are spot welded, and at various points MIG welded, this means that right from the start of production, the bare steel must have a passive coating, that allows an electrical current to pass through it, but at the same time, repels moisture, so generally, an oil based coating was applied by the steel manufacturer.
Once the body shell was fully constructed, it would need cleaning thoroughly of this coating, this was done by submerging the shell into huge cleansing tanks, and being completely submerged, holes are needed at every point on the shell to allow fluids to flood into inaccessible areas/box sections, and also to allow to drain properly.
The shell would then go on to be electro primer dipped, prior to painting, evidence of this can still be found on any body shell, by looking inside a closed box section, and finding that its coated with primer.
Holes that stop the elements entering the vehicle are then plugged with either metal or plastic grommets, the underside of the shell is then coated with thick rubberised sealer, and then off to be painted
So the holes are a very important part of the construction process, without them you car would have rusted away years ago!
Thom
« Last Edit: 03 April 2015, 11:32 by Thom89 »
Offline Waspy
« Reply #6 on: 02 April 2015, 20:53 »
Wow! Knowledge bomb there Thom! Haha thanks! So, they shouldn't/don't need/no benefit to bunging them too?
Offline Santiago
« Reply #7 on: 02 April 2015, 21:09 »
Yep, very interesting read that; thanks Thom.  :smiley:
Offline Thom89
« Reply #8 on: 03 April 2015, 00:36 »
No, don't block them off, air circulation is better than no air circulation! You can however give the box sections a good dose of Waxoyl, but only after any welding jobs have been carried out, as the Waxoyl stays very flammable for its life.
Thom
Offline Waspy
« Reply #9 on: 03 April 2015, 08:58 »
Thom
Brilliant, thanks Thom!
