Author Topic: 2.0 8v GTI Relays  (Read 2682 times)
Offline yedededos
2.0 8v GTI Relays
« on: 18 September 2005, 18:19 »
Anyone know the numbers on the ECU and Fuel Pump relays on a 2.0 GTI 8v?
Offline GTI EDITION (aka LTD)
Re: 2.0 8v GTI Relays
« Reply #1 on: 18 September 2005, 19:52 »
ECU relay is position 3 , i.e. Top left third one in on the main relay plate ( not including the added relay holders that clip in to the top )
FUEL PUMP relay is position 12 , i.e. bottom right on main relay plate  (can be a fiddle to get out with lower trim in place )
Hope this helps ,
                                 Oli  :smiley:
« Last Edit: 03 October 2005, 15:52 by GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline yedededos
« Reply #2 on: 18 September 2005, 22:51 »
Cheers mate, thats fantastic...might swap them tomorrow with relays on a fusebox i got hold of - see if it helps with the pinking and rough running.
Had a butchers today...should be an easy job - although fuel pump relay will be tight.
Offline yedededos
« Reply #3 on: 19 September 2005, 17:54 »
ECU relay is position 3 , i.e. Top left third one in on the main relay plate ( not the including the added relay holders that clip in to the top )
Hope this helps ,
                                 Oli  :smiley:
Interesting.....just swapped them over but one of them had a different number on it.
ECU was a straight swap, but fuel pump had number 80 on it, but the replacement has 167 on it - same part number though and it seems to work.
Taking the old girl for a spin tonight to see if she's cured.
Offline granthar
« Reply #4 on: 03 October 2005, 15:12 »
Did changing the relays work?
Offline yedededos
« Reply #5 on: 03 October 2005, 22:41 »
kindof...they seemed to for a while - but seems like it used to be now....so back to the drawing board.
i need this old gal 100% cos she's beginning to get me down now..........
Offline Y I GTI
« Reply #6 on: 06 October 2005, 17:50 »
relays are the most common solution to this never worked for me so a changed everything still no further foward.know how it feels wen the car gets to ya ave spent absolutely loads tryin to cure this problem mines going on a computer n gettin ecu read see if any faults mite be wise to get this done before ya start to spend money on things that dont need changin like ave done.try it first before ya spend mate
Offline yedededos
« Reply #7 on: 06 October 2005, 19:09 »
cheers for the advice mate, i'll do as you say cos i can't afford to throw money at her....unless i know it'll fix her - and hopefully an ecu scan will tell me any probs.
