Author Topic: Injectors  (Read 4385 times)
Offline Mcwill
Injectors
« on: 31 March 2015, 11:53 »
Hi guys, not posted on here for a while.
Got the golf running a 1.8t AKM with a hybrid ko4 turbo.
Have just ordered a 4bar FPR but not sure on what injectors to go for.
Awesome gti sell the Bosch 550cc but keep reading about the genesis ones but can't find any in uk for sale and not sure what the difference is.
Help would be great as due to get mapped in couple of wks.
Offline Mcwill
Re: Injectors
« Reply #1 on: 31 March 2015, 13:04 »
Also while am on the subject, I am running a mk3 16v fuel pump.
Will this be ok to run around 300bhp or do I need an upgrade and if so what's best option.
Thanks again
Offline boneybradley
  • Back in a Mk3...
Re: Injectors
« Reply #2 on: 31 March 2015, 13:35 »
I'm doing deatschwerks injectors now and they have some great help on there website to help calculate best type http://www.deatschwerks.com/
I've also just done a walbro fuel pump for a similar power output to what your needing (The Mk3 pump runs at 3 bar and wasn't enough for the power output)
http://oemandmore.co.uk/deatschwerks-18t-00-06-high-flow-fuel-injectors-set-3412-p.asp
Offline Mcwill
Re: Injectors
« Reply #3 on: 31 March 2015, 14:22 »
Thanks for that, where did you get fuel pump and how hard was it to fit?
Offline Mcwill
Re: Injectors
« Reply #4 on: 31 March 2015, 16:30 »
  • Back in a Mk3...
Re: Injectors
« Reply #5 on: 31 March 2015, 16:54 »
I sell this range too http://www.glencoeltd.co.uk/ It depends on what you want, they do a range of Mk4 replacement pumps that direct fit with higher flow. I can check into them if you want? (Some people swear by certain types but need further work!)
Offline Mcwill
Re: Injectors
« Reply #6 on: 31 March 2015, 17:47 »
I want something that is easy to install that will be able to cope with 300bhp.
The car is a daily so not keen on swerll pot as I take the kids out in car.
Thanks for the help
Rick
  • Back in a Mk3...
Re: Injectors
« Reply #7 on: 31 March 2015, 18:01 »
Maybe a P3031.1 pump http://www.glencoeltd.co.uk/hi-in-tank-fuel-injection-pump-580453711/
Plenty of write up's for fitting the mk4 on google and at £59.95 they are well priced
Offline Mcwill
Re: Injectors
« Reply #8 on: 31 March 2015, 18:13 »
Will that fit in a mk2s fuel tank?
Is it a replacment for the lift pump?
  • Back in a Mk3...
Re: Injectors
« Reply #9 on: 31 March 2015, 18:32 »
Ah I was thinking mk4 fitment not Mk2, The common pump that seems to be used on mk2 conversion is a 342 type http://www.glencoeltd.co.uk/in-tank-fuel-injection-pump-255lph-pump-only-851/
