Author Topic: Advice needed before I burn my car and give up on gti's  (Read 2459 times)
Offline Big blue turbo
Ok so I bought my car two months ago mk4 gti 1.8t drove it home from manchester with no problems.The next day and boom problem after problem and haven't drove the car since.
Ok so problem one.The windows go up and down on there own (live in liverpool so huge problem)
Problem two.starter motor gave up I have a replacement but whould like some guidance on fitting it.always worked on bikes never cars.
Problem three  running like a bag of spaners.i have put this down to the MAF but is there any way of testing this ?
Problem four wet in the drivers footwell and behind passengers seat also water pouring out of bottom of door card
Any help whould not only save my hair but also save a nice jazz blue mk4 becoming a charcoal black flour planter thanks again guys
Offline mikej20vt
Re: Advice needed before I burn my car and give up on gti's
« Reply #1 on: 30 March 2015, 08:58 »
Regarding water from door card I'd say it's probably the plastic sheeting that goes across it behind door card. I had the same problem in my old MK2 golf, especially as you say you've got a problem with the windows. Someone's probably had a look at them and ripped it off instead of removing it carefully. Have a look mate it's only a case of removing the door card, 10 mins work
« Reply #2 on: 30 March 2015, 09:04 »
Thanks for the reply will take a look today as going to try and fit the starter aswel
Offline hardmonkeys
« Reply #3 on: 30 March 2015, 09:31 »
Don't burn it pal, just take your time, and try and fix the problems, you'll get there eventually
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 30 March 2015, 09:55 »
There is no plastic sheeting behind the door card on the mk4, the window regulator panel is bolted to it.
The drain holes on the bottom of the door may be blocked or the seal on the regulator panel may be perished
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 March 2015, 09:57 »
Ideally you need to have it plugged in to find out why it's running badly and possibly why the windows have a mind of their own. What engine code is it?
