Author Topic: Dash clock to Rev counter?  (Read 2000 times)
Offline LeeOxley
« on: 28 March 2015, 18:56 »
How difficult do you think it would be to swap out a mk2 with a Speedo and Clock to a speedo and rev counter? Or maybe a rev counter gauge mounted on the dash somewhere?
Offline Mr Blue
Re: Dash clock to Rev counter?
« Reply #1 on: 30 March 2015, 17:41 »
Just a set of phillips head screws. Straight swap and you can even unscrew your current milometer and fit into a set of clocks with a rev counter.
A 90 spec car will have a single plug
early cars double plug
Offline roberto
« Reply #2 on: 31 March 2015, 22:32 »
but do you not also need wiring to coil and hall sender??? what if car is points distributor? (not 100% sure the mk2s had points???)
Offline roberto
« Reply #3 on: 31 March 2015, 22:35 »
oh and another thing is you cant use driver or gti speedo head as it is calibrated different to 1.3. driver/gti have 1540 under odometer and 1.3 has 1505.
