Author Topic: Water leaking with oil in can only see from under engine  (Read 2868 times)
Offline 2002AnniSilver
Hi all brand new to here just bought anni 1.8t and it's leaking water fast when I rev it runs much faster out the engine, on tick over it's just dripping I had a cam belt and pump done when I bought this this was around 4 weeks ago and leak only started 1 week ago so don't think it's related.
Any ideas please would be very helpful.
Percy
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Water leaking with oil in can only see from under engine
« Reply #1 on: 28 March 2015, 14:42 »
Which side of the engine is it coming from mate?
« Reply #2 on: 28 March 2015, 14:49 »
Right hand side facing the car
Offline Mr_Orange
« Reply #3 on: 28 March 2015, 23:01 »
Engine temperature sender housing? Side of block.
Build thread clicky
« Reply #4 on: 29 March 2015, 09:38 »
Not exactly sure what that is, I took off the covers and removed air filter for a better look and couldn't see where it was coming from I have seen people talking about leaks from this area of the engine.
Offline Mr_Orange
« Reply #5 on: 29 March 2015, 17:16 »
Take a look at this :
http://uk-mkivs.net/topic/10082-18t-aum-coolant-leak-fixed-inc-pics/
Common fault. Hard to diagnose. Check for water on top of gearbox.
Build thread clicky
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 30 March 2015, 09:59 »
Housing is plastic so can crack, worth a look
Offline FrankyEight
« Reply #7 on: 31 March 2015, 13:40 »
I've got a 1.8T AUM that developed a water leak, also coming from the right hand side of the engine. Got it sorted last week, turned out it was a leaking thermostat housing.
Offline Mr_Orange
« Reply #8 on: 31 March 2015, 18:36 »
Right hand side facing the car.
The thermostat housing is left-middle, up behind alternator ;)
Build thread clicky
Offline FrankyEight
« Reply #9 on: 01 April 2015, 16:09 »
All I'm saying is the I had a water leak — right hand side, facing the car — and the garage replaced the thermostat housing in order to fix it.
