Author Topic: Volume been turned down?  (Read 13398 times)
Offline Silvadadi
« on: 27 March 2015, 15:54 »
Car went into dealer for first service yesterday which was oil change and health check. Nothing else was requested but since I got it back its a lot quieter.......not sure if anything they've done software wise has altered settings for volume of exhaust system (if it can be adjusted).
Does the GTD have soundaktor internally as well?
Also noticed that when in sport the steering seems lighter than what I'm used to.  Will check to see if they've increased the tyre pressures.
Any other thoughts?
  n.b.  I'm pressing sport and normal then sport before I move off.
Ordered Jun 18: R 5dr, IG, DSG, Prets, DLA, climate w/s and tints.
Aug 14 - Jul 18: GTD 5dr, CSG, DSG, S&S pack, Vienna leather and Santiago's.
Offline Cossieian
Re: Volume been turned down?
« Reply #1 on: 27 March 2015, 16:26 »
I find when I turn from normal to sport mode my steering gets heavier, I don't like sport mode at all
Current: MK7 Golf R (Limestone Grey) DSG, 19 Prets, Winter Pack, Rear Camera, High Beam Assist, Apple Connect, Gloss Black Mirrors
Gone: MK7 Golf R (Tornado Red) DSG, Winter Pack, Keyless, Gloss Black Mirrors
Gone: MK7 Golf GTD (Pure White)
Offline phazer
« Reply #2 on: 27 March 2015, 18:03 »
That'll be massively annoying if they have altered the sound, it's great at the moment. Have to get the VCDS guys on the case otherwise.
Offline Mark V GTD
« Reply #3 on: 29 March 2015, 12:02 »
Yes it does.
Offline Silvadadi
« Reply #4 on: 29 March 2015, 22:37 »
Using VCDS any ideas where I find settings for the exhaust system.  I assume it will be separate to the soundaktor option which I've seen mentioned in the VCDS thread and will read thru to find when I get a sec
Offline Golf-Ball
« Reply #5 on: 30 March 2015, 19:44 »
Why are you pressing Sport, Normal and Sport before moving off?
Offline phope
« Reply #6 on: 30 March 2015, 20:32 »
In VCDS, controller A9 is for the internal soundaktor, with settings between 0 & 100% in adaptation channels
Controller C0 is for the external speaker for the sport and sound package, with settings between 0 & 100% in adaptation channels
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
Offline fredgroves
« Reply #7 on: 30 March 2015, 21:39 »
Whats the default values for the internal and external soundaktor?
Offline phope
« Reply #8 on: 30 March 2015, 22:11 »
They were both 100% when my car was delivered, before I turned the internal one down to 20%
Offline Silvadadi
« Reply #9 on: 31 March 2015, 01:48 »
To ensure everything is deffo in sport mode.  Peeps have had issues with starting up in sport but feeling that engine/throttle response is sluggish as if it were in normal despite sport indicated and that by selecting normal then sport before moving off sorts this.  I've just got into the habit of doing it.......might be a placebo effect thing :undecided:
