Author Topic: 16v not turning over, battery fine....HELP!?  (Read 1983 times)
Offline Tomonator1985
  • Low 'n' Slow
« on: 23 March 2015, 13:17 »
hello, it has happened intermittently before but now, key turns, nothing happens.
immobiliser is fitted but that seems to be ok, i can hear the fuel pump go when turn it off.
cant hear anything under the bonnet so solenoid is ok im guessing?
any way i can find the root of the problem rather get someone out!?
Thanks,
Tom
*MK2 Golf GTI 16v Small Bumper*
Offline Brighouse-gti
Re: 16v not turning over, battery fine....HELP!?
« Reply #1 on: 25 March 2015, 13:10 »
When you turn the key I'm guessing the oil light ect lights up on the dash?.. But then nothing.
(Assuming your fuse box, fuses & relays are all good)
Is the starter motor working?.. and if so have you tried starting the car off the starter motor not the ignition? If the car starts of the starter motor you'll know your problem is somewhere between A & B, ie the ignition barrel and the starter.
Orrrrrr possibly, similar thing with my 8v, for me it turned out the earth cable from the starter to the battery was that corroded internally it wasn't making a connection any more! Replaced with a new cable and it started better than it ever had it the 7 years I've owned it!
Offline Santiago
« Reply #2 on: 27 March 2015, 18:39 »
Deathly silence when turning key to crank engine usually means that the starter solenoid connection has corroded to the point that it is no longer a connection.  It's the red/black 4mm² wire ending in a 1/4" unwaterproofed spade connection. Unplug to inspect. Clean up if grotty, which I bet it is.
