Author Topic: The dreaded diamond cut alloy scuff marks  (Read 12721 times)
Offline GrahamFR
« on: 23 March 2015, 10:06 »
Now this is my alloy:
As you can see, somehow ive got minor scuff marks all round the middle. There are a few similar ones all across it, some in the black some in the silver. My point is these are all smooth to touch, surely there is a way to improve them if not remove them without going to a proper wheel specialist?
Tried a quick bit of wax to no avail. Ideas?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline KyleB
Re: The dreaded diamond cut alloy scuff marks
« Reply #1 on: 23 March 2015, 12:48 »
Tried a polish with fillers? Autoglym SRP might do the trick...
Offline GrahamFR
« Reply #2 on: 23 March 2015, 12:52 »
hmm i have some that came with the car i think, will give it a go, just dont want to make it worse but tbh what have i got to lose. Do you know if wheel places do like a touch up for diamond cuts or is it simply a full on £80 whack whatever they do?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline GrahamFR
« Reply #3 on: 23 March 2015, 12:58 »
Its just the lacquer that's scratched right...?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline mcmaddy
« Reply #4 on: 23 March 2015, 13:53 »
The faces aren't diamond cut its just round the outside edge of the rim.
Offline GrahamFR
« Reply #5 on: 23 March 2015, 13:55 »
I see, did not know that. So do you know of anything I can do?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Booth11
« Reply #6 on: 23 March 2015, 14:01 »
As suggested, I'd try polishing them first.  Hard to tell but if they are smooth when you run your fingernail across them, then it suggests that it may just be the laquer coat that's damaged.  Have you got a DA and small polishing pads?  If so make sure you masking tape up any vulnerable edges.  Failing that polish by hand.  Worth a try  :smiley:
Unfortunately it's a commom complaint. I've given up with mine and just suffer the scratches, kerb marks which require a full refurb  :sad:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #7 on: 23 March 2015, 14:03 »
 :huh:
I would say the face is diamond cut.
http://www.lepsons.com/diamond-cutting/
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline KyleB
« Reply #8 on: 23 March 2015, 14:04 »
I've used SRP on my wheels (admittedly not to get scratches out, just to brighten them up) and had no problems.
Really? I assumed they were Diamond Cut.
Offline GrahamFR
« Reply #9 on: 23 March 2015, 14:04 »
Ha, there would be nothing but bare metal left if i had a DA! Ill try some good old hand polishing, maybe invest in a DA in the future, can I use the DA on my windscreen too? Its something ive been thinking about tbh
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
