Author Topic: mk4 gti 2.0 missfire cylinder 1 (2003) 101k  (Read 2280 times)
Offline s999bod
« on: 18 March 2015, 20:11 »
hi my golf has developed a misfire on cylinder 1 ,have previously replaced .lambda 1&2 new cat ,new plugs, new coil and new leads ,diagnostic report says coil is being recharged on cylinder 1 to cause misfire ,anyone have any ideas whats causing this .
Is it a problem with wiring loom between coil and ecu or could it be the ecu itself.
the problem started with a misfire at 3200 revs and the ecu light flashing,i had the cat changed because it was below threshold,drove home and it was fine, next day drove 200 yards and its miss firing got a diagnostic done and the result is random cylinder misfire,now its cylinder 1 is being recharged.
any help would be great.
Offline pickles
  • Next!!!
Re: mk4 gti 2.0 missfire cylinder 1 (2003) 101k
« Reply #1 on: 18 March 2015, 20:57 »
check the wiring if you havnt already done so.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline s999bod
« Reply #2 on: 19 March 2015, 18:12 »
Diagnostics have shown its a faulty NEW ht lead.A new set has sorted out the problem.
