Author Topic: What is 'normal' Engine Coolant Temp value?  (Read 2078 times)
Offline MysteryMan
« on: 18 March 2015, 14:58 »
My 2006 Mk5 Golf GTI has always been poor at low revs and mentioned this to mechanic. He said that VWs were prone to problems with engine sensor failing and/or thermostat.
So, he suggested I monitor the "Engine Coolant temperature" when driving. I did this using Torque and gadget plugged into diagnostic socket. On normal driving, it was consistently around 65-68deg C. He reckons it ought to be higher - more like 90-100.
Is he right and are my figures too low, indicating something is not right?
Offline itavaltalainen
Re: What is 'normal' Engine Coolant Temp value?
« Reply #1 on: 18 March 2015, 21:08 »
Thermostat faulty
Offline th3_f15t
« Reply #2 on: 22 March 2015, 12:31 »
Correct, about 90 degrees is the average temperature. As mention, faulty sensors are a common VW problem.
Moving over to Flickr, sorry for the broken picture links!
