Author Topic: Sat Nav Upgrade  (Read 2276 times)
Offline JIMMYBRODIE
Sat Nav Upgrade
« on: 16 March 2015, 11:18 »
Ladies and Gents,
I have a 2010/59 GTI Dsg with what I believe to be a RNS510 Navigation System, I'm looking for a software upgrade to the nav as it is pretty much 5 Yeats out of date now.
I've been using Google maps more and more as the current nav will just give the fastest route in best conditions which as we all know isn't always the fastest route, will the update give a better handle on this?
Is there a such disc or software upgrade possible and where would I be able to do or source the required disc? Or any advice is welcome on how to get anything better then VW offer.
Thanks for all your help.
Offline AndyWard
Re: Sat Nav Upgrade
« Reply #1 on: 16 March 2015, 17:21 »
Depending on the revision of your RNS ( see sticker on top of it when pulled out) there are various updates to do to the firmware. Have a google for rns 510 firmware and do alot of reading wouldn't want to brick it now; and to make sure you get the right version for your rns.
This will make it generally quicker and enable full postcode etc; but to go with that latest maps is a must. You can go to vw and get official maps but costs £££ or can get from other places for much less £!
And once you done all of that you can go to somewhere like pocketgpsworld and get all the POI you could ever need!
10 Plate, Silver DSG,  APR Stage 2, APR TBE, Carbonio Intake 1 + 2, Bilstien B8 + VWR Springs, Eibach Front & Rear Roll Bars Powerflex Bushings, TyrolSport Subframe Deadset Collars, Whiteline Endlinks Front & Rear, Neuspeed TOP and Intercooler Pipe, R8 Coilpacks,
Offline JIMMYBRODIE
Re: Sat Nav Upgrade
« Reply #2 on: 16 March 2015, 18:28 »
Andy,
Thanks very much, I'll start to look at the firmware. Have you had any experince with any 3rd party re seller for the sat nav disc?
Thanks again
Offline J400uk
Re: Sat Nav Upgrade
« Reply #3 on: 16 March 2015, 19:17 »
On my RNS 315 you need to set it into Dynamic mode for routes for it to take into account traffic etc. I've ran it side by side with Google Maps and the ETA/ Route recommendations are pretty accurate. If you don't change that setting it will just default to trying to pick the 'fastest' route.
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
Offline JIMMYBRODIE
Re: Sat Nav Upgrade
« Reply #4 on: 16 March 2015, 20:03 »
Good advice, thanks.
Offline AndyWard
Re: Sat Nav Upgrade
« Reply #5 on: 17 March 2015, 08:28 »
I 'acquired' my maps off the internet  :wink:
Offline JIMMYBRODIE
Re: Sat Nav Upgrade
« Reply #6 on: 17 March 2015, 08:46 »
That will do! Thanks
