Author Topic: Manual Gearbox  (Read 12910 times)
Offline Cossieian
Manual Gearbox
« on: 13 March 2015, 14:54 »
Hi guys, so I've owned my GTD for just over a month now and really love it, although there is one issue that really bugs my now and again and that is trying to select reverse gear(manual gearbox).
Basically roughly 50% of the time (maybe more)I try and select reverse gear it just does not go in, I have to try about 2 or 3 times to get into reveresed and when it eventually goes in it still isn't smooth.
To begin with it didn't bother me that much but even my wife comes home and mentions it, car still only has just over 5k miles, I just feel this should not be an issue for a £25k car :sad:
I haven't mentioned to my dealer yet but perhaps I should
Seriously considering trading to a DSG
Current: MK7 Golf R (Limestone Grey) DSG, 19 Prets, Winter Pack, Rear Camera, High Beam Assist, Apple Connect, Gloss Black Mirrors
Gone: MK7 Golf R (Tornado Red) DSG, Winter Pack, Keyless, Gloss Black Mirrors
Gone: MK7 Golf GTD (Pure White)
Offline jv
  • Administrator
Re: Manual Gearbox
« Reply #1 on: 13 March 2015, 15:28 »
You are seriously considering spending a lot of money to buy a replacement car rather than ask your dealer to look at why your £25k car is hard to put in reverse?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Cossieian
Re: Manual Gearbox
« Reply #2 on: 13 March 2015, 15:49 »
Lol we are going to upgrade to a DSG car in the next year or so anyway so this wasn't the deciding factor even though I made it sound like that sorry :huh:
Just called the dealer so waiting for them to call back, what's the bets they say it's just normal :undecided:
Offline ffrank
Re: Manual Gearbox
« Reply #3 on: 13 March 2015, 15:52 »
Hi Cossieian, I've never had any issue selecting reverse in my manual GTD. Sounds like something is up with it (unless you are not pushing the stick down or something ;))
Offline Cossieian
Re: Manual Gearbox
« Reply #4 on: 13 March 2015, 16:05 »
Cheers ffrank, Im confident I'm using it correctly, now it's gonna be just a matter of persuading VW it ain't right :cry:
Offline fredgroves
Re: Manual Gearbox
« Reply #5 on: 13 March 2015, 16:08 »
Depressing the clutch all the way? I've noticed if your seat is too far back you can find forward gears with less clutch, but reverse needs it all the way.
Do you ever find it not starting when you turn the key too?
Offline KyleB
Re: Manual Gearbox
« Reply #6 on: 13 March 2015, 16:11 »
Yeah I've not had any issues with reverse. First can sometimes be a bit of a pain to get in after a stop-start (engine going off) but a dab of throttle eases it into gear.
Offline Derv_Driver
Re: Manual Gearbox
« Reply #7 on: 13 March 2015, 21:36 »
No gear selection problems with my new GTD 1500 miles and smooth into all gears.
I think the left to right gear leaver movement is converted into rotation of the shaft to the gearbox on them so maybe needs alighning and you will be fine. Try a little extra pressure over towards the passenger side and see if it engages better or maybe a little less pressure kind of holding it towards the drivers side to confirm. I might be talking rubbish and it's done differenty on these newer vw's.
Offline corgi
Re: Manual Gearbox
« Reply #8 on: 16 March 2015, 11:36 »
If you try select reverse and it doesn't go in. Take your foot off the clutch and re-depress the clutch and try again... If that doesn't work...
It is amazing how people throw their hands in the air at the slightest issue.
The tolerances in a modern gearbox are very tight - I've seen situations where a single shim can be the difference between being able to select a gear  or not -  or a slight misalignment in the selectors and wear can mean that they may need some maintenance... Assuming the car is still under warranty... the dealership should be able to diagnose and sort it...
Corgi
Offline bri
Re: Manual Gearbox
« Reply #9 on: 16 March 2015, 15:20 »
no probloms on my GTD finding reverse . but i do find going from first into second a bit notchy /sticky especially when cold ? anyone else have this ?
its going back to the dealer soon to have it looked at in any case...
MK7 GOLF GTD .CARBON STEEL GREY MET.S+S
