Author Topic: Fitting anniversary rear valance  (Read 2621 times)
Offline reedy20vturbo
« on: 08 March 2015, 18:00 »
I'm gonna be fitting the anniversary rear valance to my 2002 aum, I'm know the exhaust is gonna be hanging a lot lower the the cut out, I'm wondering if anyone else has has had the same problem and what did you do to raise the exhaust to fit nicely in the cut out, cheers
Offline Adam
Re: Fitting anniversary rear valance
« Reply #1 on: 08 March 2015, 18:11 »
You could try some shorter exhaust hangers or failing that cable tie the existing hanger around the voided bit to bring the exhaust up.
Down Hill From Here.
« Reply #2 on: 08 March 2015, 18:34 »
Good idea, I'll have a look at doing that, just don't want the exhaust hitting the floor pan where it goes over the axel
Offline Dalo Harkin
« Reply #3 on: 10 March 2015, 15:55 »
I wouldn't use cable ties, you can get poly exhaust mounts which are much stiffer, you can also get what look like metal adjustable hangars too
Offline Dizzy_PD
« Reply #4 on: 16 March 2015, 23:54 »
Sorry to jump in but where can you get these poly exhaust mounts?
My miltek is knocking on something when I go over road bumps and just rough roads, I think the mounts have had it.
Any help appreciated
