Author Topic: Coolant leak  (Read 5151 times)
Offline vwgolfv5
Coolant leak
« on: 08 March 2015, 15:10 »
I have a very annoying water coolant leak. There are no visible signs from where the leak is and my oil is clear of all signs from a head gasket.
When I had my anti freeze replaced a few months back, I asked the mechanic to give it a quick once over and he too could not see any signs of a leak.
But yet, at least once a week, my warning bleeper tells me that the expansion tank has dropped below the sensor and I have to top it up.
So, where is the water going ? and how can I fix it ?
Offline viperjsy
Re: Coolant leak
« Reply #1 on: 08 March 2015, 22:33 »
try changing the expansion tank my dash light came on and it was the tank that needed replacing
Offline hardmonkeys
Re: Coolant leak
« Reply #2 on: 08 March 2015, 22:41 »
On my mk4 it was the radiator that was leaking..very slowly.
Replaced,and all was ok
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline vwgolfv5
Re: Coolant leak
« Reply #3 on: 09 March 2015, 16:46 »
Thanks guys.
I will triple check the radiator. I don't think it is the expansion tank, it is too clean around that area, no signs at all of any leaks.
Offline Dalo Harkin
Re: Coolant leak
« Reply #4 on: 10 March 2015, 13:27 »
If there are no physical signs of a leak anywhere then it must be being burnt in the engine.
if there is no powdery white/pink (depending on colour of antifreeze) anywhere then it must be being burnt
Offline WadGTI
  • Golf GTI'er
Re: Coolant leak
« Reply #5 on: 10 March 2015, 17:06 »
Might be worthwhile letting idle at 90 for 15 mins or so, check for any leaks, give a wee rev now and then, move the car and see if there is any leakage.
Offline barrym381
Re: Coolant leak
« Reply #6 on: 10 March 2015, 18:54 »
what good will this do  :whistle:
Offline james2
  • No scammers please.
Re: Coolant leak
« Reply #7 on: 10 March 2015, 20:20 »
This ^
Mine has had 3 pin hole leaks on the same metal pipe, it would only leak when the engine was hot. Also turn it off once its at 90 and remove the coolant bottle top (slowly). Should help it leak faster.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline WadGTI
  • Golf GTI'er
Re: Coolant leak
« Reply #8 on: 11 March 2015, 10:32 »
Its a better suggestion than the one you provided to the op  :whistle:
And to answer your question Barry, I had a toyota , few years back, it had pin hole leak at the top of the rad on the hot liquid entry side which only really became visable when a) the stat opened fully taking the coolant bypass out of the equation and the coolant temp was up to 90 b, the water pump was turning higher that the idle tick over.
it might be a stupid suggestion in your view, but any suggestion is better than none in my view!
« Last Edit: 11 March 2015, 10:54 by WadGTI »
Offline barrym381
Re: Coolant leak
« Reply #9 on: 11 March 2015, 21:02 »
oh how exciting you had a Toyota once   :whistle: and if its taking a week for the coolant to drop below the sensor level I cant see 15mins making much difference
