Author Topic: Consumables during the engine change  (Read 5121 times)
Offline hardmonkeys
  • Moderator
Re: Consumables during the engine change
« Reply #10 on: 27 February 2015, 11:23 »
Ahh, brilliant, a wealth of knowledge coming through, I hope to be able to return some of this knowledge one day,
Thanks.
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline madmanmart
« Reply #11 on: 27 February 2015, 12:16 »
Don't know if this has already been mentioned but if you are changing from auto to manual you will have to bypass the inhibitor that the auto had (the safety switch that stops an auto being started unless it's in park or neutral ).I guess you will be using the loom from the donor car so this may not be an issue.
Your standard master cylinder should be o.k. but your reservoir will need changing to a 16v or vr6 one as they both have the nipple on for the pipe that goes to the slave.They just pull out/push in with a side to side wiggle.
Your pedal box should already have the bracket on to accomodate the extra pedal and mechanism for the clutch so you may not need to take dash out to add the parts.
Right so once the auto loom is ripped out (including the extra auto ECU) and swapped for the 16v loom then there will be no problems with the inhibitor.
Even the 8v master cylinder reservoir has the nipple for the clutch take off but it's blanked so all you need to do is cut the end off and attach the clutch pipe.
I would remove the dash, trying to add the extra pedal is a nightmare with the pedalbox still in situ. Plus removing the dash will make it easier to swap the looms over.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline hardmonkeys
  • Moderator
engine change week booked off!!!!
« Reply #12 on: 27 February 2015, 17:57 »
Ok, sounds good.
Booked the holiday from work, it's a little later than I wanted, but my Transport Manager has a lot of people off the week I wanted...so...from the 18th April-28th April I have to do it...is 10 days enough  :whistle:
I bloody hope so  :grin:
Offline hardmonkeys
  • Moderator
« Reply #13 on: 28 February 2015, 10:44 »
Cambelt done 10k ago, on 7/2/2012, previous owner has found the receipt  :cool:
« Last Edit: 01 March 2015, 16:29 by hardmonkeys »
VW BUSH
« Reply #14 on: 28 February 2015, 11:44 »
So its basically sat for 3 years.
I'd change the rubber and leave it at that for now.
What colour is the antifreeze
Offline hardmonkeys
  • Moderator
« Reply #15 on: 28 February 2015, 12:05 »
It's not done the mileage I would of done in it, put it that way haha, I've done 12k in my A4, since August, not sure if the water pump has been done though.
Antifreeze is pink, not tested its protection level yet, but I'll be changing it anyway, same goes,for the oil.
