Author Topic: Aliens not working  (Read 3152 times)
Offline martinc1967
Aliens not working
« on: 24 February 2015, 12:44 »
Hi Guys,
I know the aliens work on every five wash wipes etc. but mine have recently stopped working?
My washes are still working? Are they on a separate fuse or is it likely something else?
Regards,
Mart
Offline Booth11
Re: Aliens not working
« Reply #1 on: 24 February 2015, 15:50 »
Count yourself lucky they don't work, pesky things.  Do you use them much then?
See below, looks like headlight washer system does have it's own fuse #36, though exact location may vary depending on build date, options etc.
http://www.golfgtiforum.co.uk/index.php?PHPSESSID=b69lqupee5hqvs6bqst98c62i1&topic=178454.msg1677010#msg1677010
Or this but may need to look at it in reverse, as it's possibly for LHD
http://www.golfgtiforum.co.uk/index.php?PHPSESSID=gdnb62f276c99fb8kv8qenabt2&topic=200792.msg1869566#msg1869566
« Last Edit: 24 February 2015, 17:38 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline martinc1967
« Reply #2 on: 25 February 2015, 12:44 »
Thank you, I do actually. Although never really looked at the mess they make. I take it it's worse on black cars and you don't use yours?
Regards,
Mart
Offline Booth11
« Reply #3 on: 25 February 2015, 17:23 »
Regards,
Mart
Yes, they make a shocking mess on a black car, usually  jusr after it's been cleaned  :rolleyes:  May not bother some but as I'm a bit OCD about having a clean car, I find it annoying.   Plus they drain the screenwash reservoir quite quickly.
Now I'm reminded which fuse it is I think I'll pull it and then can forget about them.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline vertex
« Reply #4 on: 28 February 2015, 00:09 »
Mine don't work. After some vcds searching I found the "have headlight washers" box unticked in 09 central elect. Was via long coding helper.
Think I'll leave it off.
Offline Mattyj
« Reply #5 on: 01 March 2015, 12:49 »
It cracks me up when ppl ask if you really use them? You have no choice! As he correctly states every 5 pulls! I would prefer a seperate switch myself always come on on my clean car! ARGH!!!!!
Offline Booth11
« Reply #6 on: 01 March 2015, 13:19 »
Yes, they always know when you've just washed the car  :laugh:
No choice (unless you disable) but presumably there are some people out there that value them as a aid to cleaning.  Maybe people that don't clean their cars very often?
A seperate switch would be better than the current auto setup with the wiper stalk, but I can't think of any time I would choose to activate them, but then my lights get washed weekly/fortnightly along with rest of car so headlight washers are of no benefit.
« Last Edit: 01 March 2015, 13:22 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Mattyj
« Reply #7 on: 01 March 2015, 13:23 »
This only one occusion i would specifically want to use them,when the gritters are out!
Offline martinc1967
« Reply #8 on: 02 March 2015, 12:59 »
On Audis, they activate when you continue to press the washer stalk for over a certain time. Prob a better system as at least then you'd have the choice to use them or not.
Regards,
Mart
Offline vertex
« Reply #9 on: 02 March 2015, 17:36 »
Was digging around adaptations in 09 Central Elect. In the drop down menu, one of them offer the option to change when they activate. Standard they are set to 5 pulls, but you can change it to more or less...
For those who want to keep it...
