Author Topic: Has anyone ever seen the Damper control fault displayed?  (Read 6861 times)
Offline SR TDK
Hi everyone,
My 14 month old MK7 GTI had stood up for almost 2 months, now i seem to get Fault: Damper control and error bend lighting (AFS). They seem to go away once car has been parked in the sun, so I'm not sure if its due to the battery. taking the car to VW on Monday.I've checked online for similar cases doesn't look like its common thing.
collected 12/12/13 - MK7 Golf GTi (5 dr Manual)  in Carbon Steel Grey Metallic with:19" Santiagos, DCC, Reversing Camera, PDC and High Beam Assist.
Offline Golfgttdi
Re: Has anyone ever seen the Damper control fault displayed?
« Reply #1 on: 25 October 2015, 03:47 »
Hi did you get to the bottom of this? I'm currently having the same faults
Offline monkeyhanger
« Reply #2 on: 25 October 2015, 08:11 »
Had the damper fault light twice on my old Scirocco, each time it meant some new controller. Happened on cold spells in consecutive winters. The dampers would not work with the light, it defaulted to comfort mode (judging by how soft the suspension was), fault would clear on a new ignition cycle once the car was warm.
