Author Topic: Strange noise after fitting new abs sensor  (Read 2050 times)
Offline james2
  • No scammers please.
« on: 19 February 2015, 21:52 »
When the abs kicks in does it make a strange noise , like the tyre is rubbing on something for 1 sec ?
Im getting it from pulling away in 1st gear and did it braking on gravel tonight? I can pull away in 1st with out making the noise ,but its not normal . I have heard this noise before braking on snow and in a different car braking hard for traffic lights. ... Bloody golf  :rolleyes:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
Re: Strange noise after fitting new abs sensor
« Reply #1 on: 22 February 2015, 20:23 »
The old sensor was closer to the metal disc . Ill try and knock it in a bit more. :undecided:
Offline james2
« Reply #2 on: 04 March 2015, 22:24 »
Sorted , do not buy cheap stuff. As above, i had to grind it down.  :rolleyes:
