Author Topic: Brake bleeding kit  (Read 2362 times)
Offline WeekendMechanic
  • Golf MK3 GTD
Brake bleeding kit
« on: 17 February 2015, 14:14 »
Anyone know if the Golf 3 reservoir cap is compatible with the bleeder SEALEY VS820 BRAKE AND CLUTCH BLEEDING SYSTEM TOOL?
Offline gasketface
Re: Brake bleeding kit
« Reply #1 on: 17 February 2015, 17:35 »
I would think so,i use a gunson one and it's pretty much 1 cap fits all.Is your cap 42mm wide ?.
  • Golf MK3 GTD
« Reply #2 on: 17 February 2015, 21:33 »
Yes 42 exactly
  • Golf MK3 GTD
« Reply #3 on: 18 February 2015, 11:10 »
No it's 42mm is the one you have easybleed is the tyre pressure enough?
« Last Edit: 18 February 2015, 11:12 by WeekendMechanic »
Offline spikenipple
« Reply #4 on: 18 February 2015, 15:49 »
Tyre pressure was more than enough when I've used an easybleed kit on a MK3.
Offline gm8
« Reply #5 on: 18 February 2015, 20:36 »
tyre pressure far too high for eezibleed , 15psi max
