Golf mk4
Wazzzer
engine huntunts when i come to a stop
Topic: engine huntunts when i come to a stop (Read 2156 times)
viperjsy
15 February 2015, 22:36 »
hi when I come to a stop the engine hunts for a few secs then gose back to normal can a leaking exhaust cause this as mine is leaking from the decat after the lambada the car dose not seem down on power there are no codes
Last Edit: 15 February 2015, 22:41 by viperjsy
MoMartin
Here all the time
Re: engine huntunts when i come to a stop
15 February 2015, 22:58 »
I'd try cleaning your throttle body and check for vacuum leaks, that's the most likely cause of the engine hunting
viperjsy
15 February 2015, 23:34 »
I have cheacked pipes and no leak will try cleaning throttle body there is no power lost though thank you for your help
viperjsy
18 February 2015, 22:16 »
hi just cleaned the throttle body and now it is back to normal thank you for your help
MoMartin
Here all the time
18 February 2015, 22:31 »
No problem, i had the same problem when i first got mine, apart from mine would cut out when releasing the clutch, the funny thing is, is that the guy who had it before me thought that was normal and just put with it without checking it out.
viperjsy
19 February 2015, 00:05 »
lol
Golf mk4
Wazzzer
