Author Topic: Mk4 2001 V6 4Motion Golf Spark Plug nightmare!!  (Read 2435 times)
Offline gixerthrasher
« on: 15 February 2015, 18:17 »
Hi guys, wonder if you could give any advice about my problem here please..?
When trying to replace spark plugs I noticed I couldn't remove plugs 2 & 6 due to what looks like broken off plastic collars from old HT leads surrounding the plug way down in it's bore & preventing the plug wrench to make contact..
Tried extra long nose surgical forceps to break bits of the plastic from round the plug but I can't pull it free & back up the bore!
Worried that worse case will mean head off, drill out offending plugs, clear plug bores & refit with new gaskets, bolts etc..?
Or I persevere trying to remove little bits of the offending black/rubbery plastic rings, blow out with airline & try to get the plugs out..?
V.grateful for any help on this, car needed for work!
Never hold your farts in.. They travel up your spine and into your brain and that\'s where sh!tty ideas come from!
Re: Mk4 2001 V6 4Motion Golf Spark Plug nightmare!!
« Reply #1 on: 17 February 2015, 18:53 »
Sorted myself..
I broke bits of these offending plastic collars from round the outside of my 2 spark plugs using a long thin screwdriver & extra long forceps to remove bits & blew the crap out with an airline.. then drove a plug socket over the plugs with a rubber mallet, enough just to unscrew them with the remains of the plastic ring around the outside which you can clearly see it's from the inside of a knackered old HT lead/plug cap that broke off with a former keeper.. Obviously been like that for years as the 2 plugs were mullered on inspection!
After a final high pressured blow out of the plug wells, I fitted the last 2 new NGK Iridium plugs with a new set of ignition leads…
And Vrooom!
Perfect.. only thing is the engine warning light is on the dash & won't go out.. can I reset this myself or need a garage to do it?
Offline barrym381
« Reply #2 on: 17 February 2015, 18:56 »
buy a cheap code reader if your keeping the car  :smiley: that will turn it off and save you a few quid
« Last Edit: 17 February 2015, 18:58 by barrym381 »
