Author Topic: What gearbox (or engine) will fit my 3.5 Cabrio.  (Read 6342 times)
Offline hardmonkeys
  • Moderator
« on: 09 February 2015, 13:32 »
Well, it's looking likely a new box is needed in mine, will any engine and box fit from a mk3? Will any mk4s fit? Thinking, seeing as I'm having to put some work in replacing the box, could make a full project out of it...what will I need for complete engine changes...?
Thaks
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline hardmonkeys
  • Moderator
Re: What gearbox (or engine) will fit my 3.5 Cabrio.
« Reply #1 on: 09 February 2015, 19:00 »
Anyone know? Does it have to be a mark 3? Or can it be mk4
Offline itavaltalainen
« Reply #2 on: 09 February 2015, 19:08 »
you need a mk3 box, 020.
Offline hardmonkeys
  • Moderator
« Reply #3 on: 09 February 2015, 19:22 »
Ok, I have the 0M1 in now..auto...
Seem to be like rocking horse poo
The original question was..if I'm replacing engine and box together will mk4 engines fit..
Thanks
« Reply #4 on: 09 February 2015, 19:34 »
yeah, have a look around, lots of people have fitted mk4 1.8t in the mk3.... not plug and play though
I'd fit a mk3 manual box out of the GTI or 2.0 estate to your engine, unless you have the 1.8 engine in your convertible, then I'd fit the box from the 75hp 1.8 (longer gearing than 90hp).
Offline hardmonkeys
  • Moderator
« Reply #5 on: 09 February 2015, 19:38 »
I was considering the option of converting to manual...big job?
« Reply #6 on: 09 February 2015, 20:44 »
Dunno if AGG ECU for auto is different but don't think so.... you will need manual fly wheel I'd imagine, gearbox, obviously all the hardware to change gears in car.... different pedal cluster I'd think......
Not straight forward but people will have done this. Ask your buddy at VW garage, if they are friendly (and been there when mk3 was around) they can probably give you a good idea.
Bit more tricky then straight forward mk3 auto box transplant but easier than fitting manual (or auto) mk4 engine and box
Offline hardmonkeys
  • Moderator
« Reply #7 on: 10 February 2015, 02:27 »
Excellent, thanks
Will continue the search for an auto aswell,
Offline hardmonkeys
  • Moderator
« Reply #8 on: 10 February 2015, 18:14 »
The EPR code isn't listed on this,
as long as it says it's for a 2.0l Golf, can i assume I can search for any of the gearbox codes? As the EPR is apparently difficult to get hold of...or is the EPR for the 8v
« Last Edit: 10 February 2015, 18:16 by hardmonkeys »
Offline vwwvgolf
« Reply #9 on: 10 February 2015, 19:27 »
you could always take it out yourself and get it reconditioned and stick it back in?
