Author Topic: New to the Forum and a new Mk3 Gti owner :)  (Read 2083 times)
Offline 8 valve GTi Mk3
« on: 05 February 2015, 01:10 »
Hi people, am a new Mk3 Gti owner and always find the forums excellent fountains of information and good banta, got my self a 96 Mk3 Gti 2.0 8v, stood for over 2 years need lots of tlc and work, but had to save the Gti from the scrapyard. I hate a good car going to the vultures or crusher, have done the plugs, leads, rotor, cleaned the cap, oil and filter, throttle body clean and adjustment, clutch cable and fuel filter.
running a lot better than first getting going only a few lambda intermittent faults picked up but could need driven for a while and some V-Power and Forte Gas Treatment through, will check again after a few days but does sometimes hold back, but only changed the fuel filter tonight, and it had never been off in years! and put some V-Power in to start cleaning so maybe will cure the problems hopefully.
Has a Piper Cross cone and a Scorpion cat back de/cat system standard other wise apart from some 17" Wolfrace Ultralites and a spray a while back, probably go back to airbox and panel filter as not a fan of cone filters, does need some attention to floor plugs and sills, also needs a release bearing as hard to engage first sometimes and making a racket, and over cooling but needs flushed and a thermostat I think? has 183000 miles but full service history and an 80k engine fitted so worth the effort, very good inside and all works bar heater dials on it's way and sagging headlining, I like the car and reasonable for 115 bhp I was very surprised at acceleration when working correctly, here's some pics :)
and picked up these beauty's getting done gloss black at the minute and new bbs caps
will look awesome with these on, I can't wait, let me know what you think people and any tips appreciated :)
« Last Edit: 05 February 2015, 01:19 by 8 valve GTi Mk3 »
VW BUSH
Re: New to the Forum and a new Mk3 Gti owner :)
« Reply #1 on: 06 February 2015, 20:40 »
Search the following in the mk3 section.
Coil (buy one anyway)
Fuel relay^^
ECU relay^^^
Timing/5500 rev limit
Throttle body (clean it anyway)
Crank angle sensor
Hall sensor (ref 5500 limiter)
U281 code reader (buy one anyway)
Rusty sills/floor/arches
ABF/20VT conversion
ABS sensors and pump/ecu
Enjoy, looks like a nice motor :smiley:
« Last Edit: 06 February 2015, 20:41 by VW BUSH »
Offline GTI_Ant
« Reply #2 on: 23 February 2015, 22:53 »
Hope you are enjoying it.  Regarding your comment about 115bhp - it isn't bad at all - cars get heavier and heavier with each new model (MK 7 is an exception) so need more power to stay the same.  My MK 2 had 112bhp and was a desirable fast motor at the time.  The MK 3 is just fine with 115.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
