Author Topic: Uneven tyre wear (fronts only)  (Read 4626 times)
Offline Hawaii-Five-O
  • Are we nearly there yet?
« on: 03 February 2015, 21:35 »
Hi All,
Not posted anything in ages but here's the thing... is anyone experiencing the same problem? Getting uneven wear across both front tyres. It's occurring across the middles. Below 3mm now after 15k. Both left and right edges are still quite good at around 5mm. Now this would suggest over inflation. However I'm fastidious about keeping pressures balanced at the recommended 36psi. Do you guys think that's too high and leading to increased wear in the middles? Just so you know the rears are also kept at 36psi but their wear is evenly distributed across the tyre.
Any suggestions?
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
Offline Fabio Bignose
Re: Uneven tyre wear (fronts only)
« Reply #1 on: 03 February 2015, 21:56 »
My mk6 GTD did this as did my current MK7.
Both had Bridgestones from factory and then both had continentals thereafter and were fine.
Pressures were always correct which was verified by fitters at time of changing so ive no idea why they wore like that.
Just a characteristic of the tyre i suppose albeit a pretty sh!te characteristic....
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline fredgroves
« Reply #2 on: 03 February 2015, 22:45 »
I agree - my Tombstones were worn just like that - despite being correctly inflated.
Why? No idea, the tyre fitter had no clue either.
« Reply #3 on: 03 February 2015, 22:46 »
BTW they are Continental's fitted at the factory.
Offline fredgroves
« Reply #4 on: 03 February 2015, 22:48 »
Sounds like some kind of MQB funny then...
« Reply #5 on: 03 February 2015, 22:50 »
Maybe... but is this problem common or isolated? That's what I'd like to know. And can it be offset by lowering the pressure by a few psi?
Offline 2014GTi
  • Das Auto
« Reply #6 on: 03 February 2015, 22:51 »
I would check your tyres to ensure they are the same type.
I found out when I came to replace my Pirelli P-Zero tyres @ 15k miles that the dealership must have replaced a tyre at PDI from new, they tyre was replaced with a Star (*) model of the same tyre which is a run-flat variant for BMW only cars!
Hence why my front tyres wore unevenly and it also used to cause the driver side pressure monitor to always trigger every so often.
I had no idea I had been driving for 15k miles on a mismatched pair of front tyres!!!  :whistle:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline monkeyhanger
« Reply #7 on: 04 February 2015, 07:55 »
Not had this on the current Bridgestones, but the front tyres that came with my last Scirocco 170TDI (Pirelli P7s) were terrible for this - the central 1/3 was down to the markers when the outer 1/3 either side had a healthy 6mm, at 11k miles. Michelin PS3s went on the front in replacement and they wore evenly. Kept a close eye on the tyre pressures - never overinflated. I'm sure Sootchucker had P7s on his 140 Scirocco and never experienced the same issue though.
Maybe the "one size fits all" tyre pressure sticker in the fuel filler flap isn't correct for all types of tyre (leading to overinflation that's fine for one tyre but not for another), or maybe a few of us get crappy geometry set-up that some tyres tolerate more than others?
« Last Edit: 04 February 2015, 07:58 by monkeyhanger »
Offline fredgroves
« Reply #8 on: 04 February 2015, 08:02 »
If it was geometry then surely that would wear inside or outside, not the centre?
I'm a bit of a muppet with car tech, but that's what I can only think of at the moment.
Offline corgi
« Reply #9 on: 04 February 2015, 09:07 »
Agreed.
Is the band in the middle well defined i.e. it doesn't have wavy edges?
It does sound like over inflation. Tyres on mine have worn evenly for all of 24K miles...
Corgi
