Author Topic: gearbox speed/revs/gear for 16v  (Read 2797 times)
Offline vwwvgolf
« on: 03 February 2015, 18:17 »
hi,
just fitted lightened flywheel and recon'd box with the 3.9 F.D. pretty sure its CDA code
any one got what the speeds should be at certain rev in the gears. just want to check that they did actually change the F.D when it was remade
thanks
VW BUSH
Re: gearbox speed/revs/gear for 16v
« Reply #1 on: 03 February 2015, 21:01 »
1st 3.300    2nd 1.944   3rd 1.308   4th 1.029    5th 0.837
Old FD 3.684
New FD 3.9 (which 3.9 FD is it? there are a few with slightly different ratios)
So calculate road speed as engine speed in RPM through the gear+FD ratio and circumference of wheel into m/s then convert to mph.
hope that helps.
I have a spreadsheet I can mail out if anyone needs it of all VW box ratios and trans info.
Or if someone can suggest a way of posting it on here....
Offline vwwvgolf
« Reply #2 on: 04 February 2015, 12:39 »
it should have the 3.94 FD fitted.
so if i wanted to find the speed of old box in 5th, i would do: 0.837+3.684+ 1353(i think is the diameter of wheel) then what?   was never anygood at maths!
VW BUSH
« Reply #3 on: 04 February 2015, 23:34 »
http://en.wikipedia.org/wiki/Gear_ratio
Bottom of the page, easier than me trying to explain :wink:
Offline vwwvgolf
« Reply #4 on: 05 February 2015, 19:48 »
cheers man ill try get my head round this later
Offline vwwvgolf
« Reply #5 on: 06 February 2015, 12:21 »
http://www.boosttown.com/gearbox_differential/speed_calculator.php
used this to help. much easier! thanks for the ratios tho!
VW BUSH
« Reply #6 on: 06 February 2015, 20:26 »
No probs.
I've got an engineering calculator I use for this sort of thing.
It's amazing how quickly you forget 7 years at college and become a retard :grin:
VW BUSH
« Reply #7 on: 06 February 2015, 20:26 »
No probs.
VW BUSH
« Reply #8 on: 06 February 2015, 20:28 »
See
Offline vwwvgolf
« Reply #9 on: 07 February 2015, 08:48 »
ive forgotten nearly everything from school lol i blame beer!
