Author Topic: Squeel from inside cabin...  (Read 4529 times)
Offline ajmoir36
Re: Squeel from inside cabin...
« Reply #10 on: 03 February 2015, 20:14 »
Presumably your R is not one of the early ones, very few of which suffered with blown turbos. Personally, I would not worry too much at the moment. Try deactivating the little bugger that provides the false sound and if the squeal is still there, take it back to the dealer. It might be just how the R is and you have to accept it.
I have a 722A car is registered Sept 2014. Will try the sound actuator.
Turbo
by Techie_Ali, on Flickr
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Mr Savage
« Reply #11 on: 03 February 2015, 21:28 »
If you've already been driving in normal mode then your sound actuator will already be disabled. It only operates when you're in race mode or have the engine set to race setting in individual mode.
Just drive it as normal and don't worry about it because chances are it's nothing. If it gets worse take it to the dealer for warranty work.
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline ajmoir36
« Reply #12 on: 04 February 2015, 17:45 »
The noise you have all been waiting for http://youtu.be/iaM0bXPCLbM I have enhanced the sound by lowering all frequencies which includes the bass tones and raising the volume of all frequencies between 3.5-7.5KHz, this was to try and remove the engine noise, sound was recorded whilst in normal mode. It also starts pretty much instantly 2seconds ish.
Offline am1w
« Reply #13 on: 04 February 2015, 18:02 »
I hear a high pitched whistle. Not a squeak like a mouse! As I don't have my R as yet, this might be how it is meant to be. Would drive me a bit potty, so I'll turn up the Dynaudio system and deactivate the Soundaktor.
BTW, does this happen when the engine is cold or at all times?
Offline ajmoir36
« Reply #14 on: 04 February 2015, 18:08 »
With throttle applied. Stops when idling and obviously to much go and there is to much noise. I am convinced is the fuel pump. Hot and cold. Mine doesn't sound like this...http://youtu.be/mx-HKgZM_tc maybe it sounds like this except not as bad https://www.youtube.com/watch?v=AglZYZ7bZMA
« Last Edit: 05 February 2015, 16:49 by ajmoir36 »
Offline ajmoir36
« Reply #15 on: 05 February 2015, 17:14 »
Got it booked in with VW now to be looked at on Sat, I will wait and see what they think it is.
Offline ajmoir36
« Reply #16 on: 07 February 2015, 18:06 »
Took it to vw today mechanic could hear it thought it sounded a little odd but we took out another R and it was the same so put it down as being normal for now.
