Author Topic: Stub axle  (Read 2511 times)
Offline Craigwilson
Stub axle
« on: 29 January 2015, 23:43 »
so I had a little accident in the snow last night involving me sliding sidways into a kerb with my left rear wheel, it was a considerable force, enough that I braced myself as I knew it was happening. is it likley that there is any damage to the axle or even the chassis? the impact did knock my split rear seat out of place.
Offline Craigwilson
Re: Stub axle
« Reply #1 on: 30 January 2015, 19:48 »
will a mk3 1.4 rear axle fit the gti?
Offline boneybradley
  • Back in a Mk3...
Re: Stub axle
« Reply #2 on: 30 January 2015, 23:05 »
It will fit (same part..b.t.w new febi are only £30 http://oemandmore.co.uk/stub-axle-rear-with-disc-brakes-217-p.asp)
Offline Sgt_Lemon
  • 8v owners club
Re: Stub axle
« Reply #3 on: 31 January 2015, 13:37 »
Fit the new stub axel and then check the disk runout on that axel. If the disk is straight and you are getting runout then something else may be bent also.
Offline Craigwilson
Re: Stub axle
« Reply #4 on: 02 February 2015, 01:26 »
new stub fitted and it turned out the axle was bent, I replaced it with a wider mk3 axel and its sitting off centre, the gap between the mounting plates and the axel is different by about 10mm what can cause this? I did have a bit of difficulty getting in to fit, felt like the bushes were too wide
Offline Sgt_Lemon
  • 8v owners club
Re: Stub axle
« Reply #5 on: 02 February 2015, 21:58 »
Sorry, not sure. What exactly do you mean by off centre. In what diection?
Offline Craigwilson
Re: Stub axle
« Reply #6 on: 05 February 2015, 01:06 »
the axle is sitting over to the right hand side of the car, not in the middle
