The garage
Misfire, idle smooth
Topic: Misfire, idle smooth (Read 2233 times)
bikeman
28 January 2015, 19:08 »
Coming home this evening, literally 100 yards from my house, I suddenly get a misfire in my 1.8T. Engine wont rev and sounds rough. But it ldles smoothy and doesn't stall.
Crank sensor, coil pack? Help me diagnose please.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Misfire, idle smooth
28 January 2015, 19:12 »
Scan for fault codes and also look at measuring blocks...... why guess if you can get an indication of fault through codes?
bikeman
28 January 2015, 19:18 »
Alas a scanner is something I had always intended to buy, maybe next time. For now though I need possible causes to look at when I'm sitting at home tomorrow cause I wont be going to work now.
bikeman
29 January 2015, 12:16 »
Fixed - an ignition coil had failed.
The garage
