Author Topic: Gamma Radio change over to Single Din Headunit  (Read 3987 times)
Offline Lucasprss
« on: 26 January 2015, 22:22 »
Hi peeps, need some audio advice. I have just got myself my first golf GTI MK4 (115) 2001 (red and black interior) which has the standard Gamma Radio in and above it is an empty din unit.
I have a kenwood kdc-455u single din headunit to replace the gamma radio, do I need to buy additional wire harness for it / plastic housing for it aswell or should it just be a case of swap out.?
Any help is greatly received. Thanks
Offline hardmonkeys
Re: Gamma Radio change over to Single Din Headunit
« Reply #1 on: 27 January 2015, 02:34 »
Should be ok to swap over without additional housing, I *think* (as far as I can remember) you won't need any additional wring harnesses either, it's been a while since I did a radio change in a mk4...best thing to to remove the old Gamma unit and have a look at the wiring, easy enough to do
Hope that helps
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline Lucasprss
« Reply #2 on: 27 January 2015, 06:35 »
Thanks for your reply, I'll remove the unit and have a look.
Offline Dalo Harkin
« Reply #3 on: 27 January 2015, 13:58 »
Its standard 2 block wire harness.
Offline Lucasprss
« Reply #4 on: 27 January 2015, 21:11 »
Standard two block harness is that Good.?
With aftermarket head units do I need to buy an ISO adaptor?
Offline hardmonkeys
« Reply #5 on: 27 January 2015, 21:34 »
No, the two block connector is ISO
Offline dubber36
« Reply #6 on: 28 January 2015, 09:30 »
I'm pretty sure you'll need to swap the permanent and ignition lives over in order for the new radio to keep its memory.
It's easier to buy an adaptor lead which has bullet connectors on the red and yellow wires to enable you to do this, than it is cutting and soldering the cars existing wiring.
Offline hardmonkeys
« Reply #7 on: 28 January 2015, 14:18 »
Ahhh, good point, I stand corrected
Offline Dalo Harkin
« Reply #8 on: 28 January 2015, 17:14 »
I didn't change any wiring on mine and it remembers all the settings.
Offline dubber36
« Reply #9 on: 28 January 2015, 17:36 »
Does it turn off in the same way when you take the key out?
