Author Topic: Golf 2lt autobox issues  (Read 5926 times)
Offline hardmonkeys
  • Moderator
« on: 26 January 2015, 11:40 »
Hi all, been looking at a golf cabrio today, it's an 'w' reg, when you start it up, and Put it in drive or reverse, the engine stalls until it's warm,  any ideas on what could be causing this?
Also when the engine is warm the clutches and brake bands in the auto box slip. This is worse in third and fourth, any ideas? I'm thinking if I do get it, it would be easier to replace with a recon box?
Easy to do?
I'm new to mk3s so any help I will be grateful for.
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline gasketface
Re: Golf 2lt autobox issues
« Reply #1 on: 26 January 2015, 15:51 »
I don't know if this will be any help but the only experience i have of auto boxes is with Fords from the 80's and 90's.
If someone with a Ford from that era described the same symptoms i would guess that the stalling problem could be down to the vacuum operated modulator on side of gearbox but i have no idea if Golf has one .
See post starting "well i'm in a bit of a quandary " about half way down page :- http://retrorides.proboards.com/thread/36624/1986-ford-granada-mk2-hearse
One of the most common and simple to sort problems on an auto box is caused by irregular oil changes or incorrect oil top up,it can also be incorrect adjustment of the kickdown cable or a combination of both.
Many auto's require a certain procedure you have to go through when topping up the box level,it's not like topping up the engine oil and can be easily screwed up if you don't know the process.It differs from car to car,make to make.I have never worked on a MK3 sorry so cannot advise.
I have had quite a few cars come to me with symptoms as you describe and most have been sorted by an oil flush, and change to the correct level.
If you decide to go ahead i suppose you have to look at the worst scenario and work out the cost of another auto box but you could also consider changing it to a manual and use the running gear from a 16v which has a stronger gearbox than the 8v.
Good luck.
Offline hardmonkeys
  • Moderator
« Reply #2 on: 26 January 2015, 17:07 »
Thanks for your reply, you could be right about the lack of gearbox maintenance, I've looked thought the receipts and not seen a service on it, might attempt gearbox oil change, before I do anything drastic like replace the box haha
Offline hardmonkeys
  • Moderator
« Reply #3 on: 27 January 2015, 17:53 »
Hi, I've been asking a few people about this problem with the gearbox, one of the delivery drivers from my wife's work, old boy, in his 70-80s, says best thing to do is drain the oil, fill with Thinners, to clean the internals, empty and then refill with ATF, I've never heard of this way before,  any ideas? not sure I want to do it this way, is there an actual gearbox flush, I'm a complete newb when it comes to the Auto Box...
Also, I went on Honest John ( Iknow, I know) and it says there is a common fault with the 4 speed Autobox,
'4-speed autobox can have problems. Since VW dealers charge £4,000 for a new one, this is best sorted by an independent specialist. Often no more than an oil control valve'
Oil control valve?? Any ideas where to find this? Might/could need changing,
Thanks
VW BUSH
« Reply #5 on: 27 January 2015, 20:48 »
I've flushed auto boxes many times ( 80's Volvo's leak coolant into the gearbox for fun).
You can do it at home but its a fag, needs two people and a sh!t load of ATF.
I have used flushing agents with mixed results :lipsrsealed:
Phone around first to get some prices from a box specialist, should only take an hour or so with the right kit.
Offline hardmonkeys
  • Moderator
« Reply #6 on: 27 January 2015, 20:58 »
Excellent, thank you both, all interesting reading
Really looking forward to getting my teeth into this
VW BUSH
« Reply #7 on: 27 January 2015, 22:02 »
If your going to do it flush it from the cooler on the rad, use the pipes going to it and some flexi you can clip over them to get to a bucket. One pours in, one keeps the pipes in the bucket and an eye on the level don't let the box run dry or you will be bleeding air out of it foh ever and ever.
You could get very messy so cover up well ATF stains mums nice driveway and is not to good for paint
I once flushed a box with engine flush and it broke off 160000 miles of crud into the inner workings.....(this is where i honed my Volvo box bleeding skills in preparation for the coolant leak saga into the box via the cooler grrrrr)
Got away fine a couple of other times with flush but this was on the solid Borg W drive not the PRV crud.
Its just less of a pita to use ATF to flush, just takes a while longer.
Offline hardmonkeys
  • Moderator
« Reply #8 on: 28 January 2015, 19:15 »
Went into the local VW dealer to ask the service advisor, I'm very friendly with this guy, he helped me a lot with my previous VWs, and he is very knowledgable, anyways, I explained my problems with the gearbox, and like everyone is saying here, to drain the box and renew the oil, but he also came up with another fix...the relay for the autobox...so I'm going to giving that a try, got to find which one first...wish me luck  :laugh:
Offline hardmonkeys
  • Moderator
« Reply #9 on: 29 January 2015, 17:43 »
hi again, i totally forgot i had a snide copy of VAG-COM...i know i shouldnt, but i got off a guy on here...so..thats my excuse lol...anyways
here is what my scan produced
VAG-COM Version: Release  311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01     -------------------------------------------------------
   Controller: 037 906 025 R
   Component: SIMOS 4S           2572
   Coding: 00001
   Shop #: WSC 00672
No fault code found.
Address 02     -------------------------------------------------------
   Controller: 01M 927 733 FR
   Component: AG4 Getriebe 01M    4161
   Coding: 00000
   Shop #: WSC 00000
4 Faults Found:
00518 - Throttle Position Sensor (G69)
            16-10 - Signal Outside Specifications - Intermittent
00638 - Engine/Transmission Electrical Connection 2
            03-10 - No Signal - Intermittent
00300 - Transmission Fluid Temp. Sensor (G93)
            34-00 - No Malfunction Detected
01192 - Torque Converter Lock-Up Clutch
            04-10 - Mechanical Malfunction - Intermittent
Address 03     -------------------------------------------------------
   Controller: 3A0 907 379  D
   Component: ABS     ITTAE 20 GI V00
   Coding: 03704
   Shop #: WSC 00672
Skipping Address 15-Airbags
Address 25     -------------------------------------------------------
   Controller: 6X0 953 257
   Component: IMMO                0003
   Coding: 00001
   Shop #: WSC 00672
   WVWZZZ1EZYK016131     VWZ1Z0Y0445130
1 Fault Found:
01314 - Engine Control Module
            65-10 - Unauthorized - Intermittent
Address 56     -------------------------------------------------------
   Controller: 1J0 035 186 D
   Component:  RADIO SON         0003
   Coding: 07403
   Shop #: WSC 00672
End   -------------------------------------------------------
anyone seen anything like this? i have looked in Ross wiki, but the 1st two don't show up,
but, 00300 - Transmission Fluid Temp. Sensor (G93) - Implausible Signal
Possible Symptoms
MIL On
Transmission Not Shifting Properly or in Limp Mode
Possible Causes
Wiring/Connectors from/to Transmission Fluid Temp. Sensor (G93) faulty
Voltage Supply for Transmission Fluid Temp. Sensor (G93) faulty
Possible Solutions
Check Wiring/Connectors from/to Transmission Fluid Temp. Sensor (G93)
Check Voltage Supply for Transmission Fluid Temp. Sensor (G93)
Check Measuring Blocks for Transmission Fluid Temp. Sensor (G93) Readings
Check / Replace Transmission Fluid Temp. Sensor (G93)
and
01192 - Torque Converter Lock-Up Clutch: Mechanical Malfunction
Possible Symptoms
Torque Converter Lock-Up Clutch slipping
Possible Causes
Torque Converter Lock-Up Clutch faulty
Valve Body faulty
Internal Failure in Transmission
Possible Solutions
Check Torque Converter Lock-Up Clutch Slip
Special Notes
When found in 4-Speed Automatic Transmission (01M), check Measuring Value Block (MVB) 007.
not had chance to look into the MVB yet, but it'll be interesting to see what it shows...
