Author Topic: Spacer  (Read 2684 times)
Offline GTi_James
Spacer
« on: 22 January 2015, 19:02 »
evening all,
been a while since posting on here but looking to get back in it!
need some spacers to fit to the ol'girl and have come across these...
http://www.ebay.co.uk/itm/4-Billet-Wheel-Spacers-5x100-to-5x100-1-Inch-Thick-25-mm-56-1-12X1-25/281346662751?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D0ae09e0d3bc24637a7525c1e39bd2bc2%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D160902765545&rt=nc#ht_4055wt_952
anyone used these? i know theyre thick at 25mm per wheel but hey-ho, want stanced then get stanced
seen these types knocking about but wondering if anyone has actually used or seen them used?
thouhts please?
Offline topher
  • Administrator
  • fully functioning
Re: Spacer
« Reply #1 on: 22 January 2015, 19:28 »
they're not hubcentric so will most likely wobble like f*ck at anything above crawling pace
Offline GTi_James
Re: Spacer
« Reply #2 on: 22 January 2015, 19:39 »
would that be a concern seeing that it bolts to the hub and the wheel bolts to the spacer?
VW BUSH
Re: Spacer
« Reply #3 on: 22 January 2015, 19:48 »
You will have no line up between the hub spigot and wheel. Even if you got it close when you hit a bump the wheel will move off centre and shake you to high heaven.
Bolts will eventually snap or strip out the threads leaving you with a three wheeler.....
Offline GTi_James
Re: Spacer
« Reply #4 on: 22 January 2015, 19:55 »
Offline GTi_James
Re: Spacer
« Reply #5 on: 23 January 2015, 17:35 »
anyone?
Offline viperjsy
Re: Spacer
« Reply #6 on: 23 January 2015, 19:22 »
you will need longer bolts
Offline Greg_ED35
  • Golf GTI Edition 35
Re: Spacer
« Reply #7 on: 23 January 2015, 19:59 »
Will put a lot of stress on your bearings also with a 25mm spacer, i know not always a concern but worth keeping in mind !
