Author Topic: Rear beam way out  (Read 3191 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Rear beam way out
« on: 22 January 2015, 09:02 »
Got my car tracked earlier this week which sorted out the front wheels, but as we all know the rear ones are not adjustable. So how can I sort out the rears!?
I put a print out up later but the are both pointing inwards by a couple of degrees...
Bent rear beam? Bent wheels? Bearing in wonky? What the hell can cause this?
Offline Simeon
Re: Rear beam way out
« Reply #1 on: 22 January 2015, 13:02 »
I think the only way to fix this is trial and error with adjustable camber shims
VW BUSH
« Reply #2 on: 22 January 2015, 19:51 »
Can you shim the stub axle to correct it?
Offline scarr89
« Reply #3 on: 23 January 2015, 21:11 »
This is the print out after - So front wheel are running straight, atleast toe in/out!
The rear wheels are all over the shop!
Surely you'd have to spend alot to recitify all of this!  :sick:
Offline LR5V
« Reply #4 on: 23 January 2015, 22:16 »
Shims are not trial and error, with the figure you have in the print out you could correct this with Eibach ones.
Kermit the frog explains shims here-
https://www.youtube.com/watch?v=rLggvBqh1uU
But I would look at your rear bearings first
hand brake off, brake pads eased off the disk & wheel back on you should be able to feel play if its there.
Offline scarr89
« Reply #5 on: 23 January 2015, 23:39 »
Interesting vid, never seen these things.
I'll try giving my bearing a wobble.
I am not a perfectionist but knowing that all 4 wheels are on the piss, and not evenly annoyed me so much!
Offline Bandit127
« Reply #6 on: 24 January 2015, 07:21 »
What are the specs for the rear geometry? I doubt it is 0.00 all over.
TBH, you have less than 0.6° of total toe (and that is toe in, not out) and -1° of camber either side. I don't see anything wrong with that  As long as the bushes and bearings are OK I would be perfectly happy with it.
Offline mcgee9t2
« Reply #7 on: 27 January 2015, 13:03 »
+1 on the above. its nothing, you certainly wouldnt notice any difference in a mk4.
Offline scarr89
« Reply #8 on: 27 January 2015, 14:28 »
Ok, cheers guys.
I'll tone down my OCD.
