Author Topic: Indicator problem!  (Read 1992 times)
Offline benmanc
Indicator problem!
« on: 15 January 2015, 20:24 »
My indicator is not staying on. It does it both sides basically flashes a handful of times then goes off.
It does it when on full and also if I hold down before the 'click' to make it stay on.
Any ideas?
Offline benmanc
Re: Indicator problem!
« Reply #1 on: 16 January 2015, 14:40 »
Update: it did it with hazards too and so I replaced hazard switch from scrappies and it works perfect now.
In fact the indicator sound is different (better) now.
Thanks for all your help and comments  :whistle:  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 16 January 2015, 17:23 »
Only just seen this....
Hazard switch failing is a common Mk4 fault as it has the relay built in to it
