Author Topic: mk 4 clutch  (Read 1953 times)
Offline rorywatts
mk 4 clutch
« on: 15 January 2015, 18:19 »
hi dont know if any one can help i have a mk4 1.8t gti 2001 im having problems with the clutch it was working fine today but when i went to drive home from work i could not engage gear with the engine running and when i turned it off and engaged a gear and tried starting it it lurched like the clutch was not being pressed seems strange how the clutch could just fail while the car was parked up and i had not had any problems before
Offline Tezmax
Re: mk 4 clutch
« Reply #1 on: 15 January 2015, 19:57 »
Hi and welcome to the best VW Golf Forum on the planet... :whistle:
Your standard 18t clutch will fail just like any other, either it will wear out slowly and begin to slip or disintergrate and fail instantly.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline stina
Re: mk 4 clutch
« Reply #2 on: 15 January 2015, 21:35 »
That sounds like either master or slave cylinder .
Offline Dizzy_PD
Re: mk 4 clutch
« Reply #3 on: 18 January 2015, 18:05 »
It does sound like a faulty slave cylinder..
Same thing happened on my b7 a4 a while back, one day out of the blue it wouldn't engage any gears.
Changing the slave fixed it.
